Question about Tricity Bendix AW1400W Front Load Washer
Trying to change the carbon brushes but can't find a socket the right size any ideas?
Trying to change the carbon brushes as the one on the left has been totally worn away and the drum won't now spin . brought the new brushes but can't find a socket the right size to take the old ones out
  • lainy1975 Oct 28, 2008
    brushes need changing but dont know were they are?
  • Anonymous Mar 12, 2014
    cant remember at which angle to replace carbon brushes
All done it was the brushes on both sides of the motor and borrowed a tool set to do it only cost £7 each and the machine is back on
Posted on May 01, 2008
2 Suggested Answers
grandadfixer
  • 99 Answers
SOURCE: trying to change the carbon brushes but can't find a socket the right size any ideas?
defo carbons buy right tools.
Posted on Oct 18, 2008
I have a 10" mastercraft hawkeye sliding mitre saw and i need to replace the carbon brushes but i can't find brushes anywhere!!
you need to know the size, brushes are all sizes. take the old ones out and measure the size of what is left of the bush. then measure the length of the case it sits in. and take 10mm off the end of the length of the case and that is the size you need. then look on ebay at bushes and look for one's that size. or go on maplins web site If in UK, if in another country look for electrical suppliers they should be able to help with the size you have given them.
Nov 07, 2013 | Saws
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
I have a aeg ph38 electric 800 watt chipper hammer, i need to find carbon brushes and the carbon brush holders for the tool.
RE AEG PH 38 Brushes go to local hardware storeinthe miscelleanous everything aisle and look or a SKIL brush set exact size match $4.50 US cost I fixed mine today. Brush holders another issue
Apr 25, 2011 | Garden
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
How to change carbon brushes in Vax 2000
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Aug 31, 2008 | VAX Appliances Vax X5 Bagless Upright...
Tricity Bendix AW1400W Front Load Washer Logo
173 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
