Question about Car Audio & Video
Brake bypass code
  1. I do not understand how to enter the brake bi pass code and do not know the code.
  • hseman Apr 28, 2008
    Phase Linear UV8
  • 13,433 Answers
Need to know more about your device. brand, model.
Posted on Apr 28, 2008
  • Ekse Apr 28, 2008
    from remote press setup then 5 4 3 2 1 0 it should beep after every number (hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
I have the same make and model (xdvd8183. However, the blue warning screen will not go away. I can hear sounds and change chapters but no video. I also want to watch without the parking break engaged but there is not "set-up" button on my remote.
Posted on Dec 19, 2008
  • 758 Answers
Could you please provide more info about your device? The brand and model.
Thank you
Computerrep
    Guru:
  • 731 Answers
put a movie in
1. Press STOP twice on the remote
2. Enter: 26604 on remote
3. Press ENTER
thats it!
Thanks
Riz
    Brigadier General:
  • 3,614 Answers
I want to know the model and part # of the unit.
Thanks
    Genius:
  • 3,422 Answers
Can you please give the make and the model no. so that i can help you fix it.
  • Priya darshan Apr 28, 2008
    Ok, here is the solution
    use remote to activate am/fm then hit setup on rem.enter 543210 and a
    new menu came up. ( listening for the beep after each 3 is pressed )
    select the hammer in upper left hand corner of screen, select brake
    bypass to on, then hot the X near bottom os screen.
    hook up the ground with the pink and when you are in am/fm mode hit the
    dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0
    make sure it beeps after every no. has been pressed. then it should
    bring up the hidden menu select the hammer option and turn on the brake
    bypass option. your done
John deere gx255 shuts down when brake released.
For sure the seat switch is the likely problem. The logic is if the brake is set the engine will start and run. If the brake is released and no driver in seat a saftey situation is possible and the engine turns off. Check seat switch, Bi pass to troubleshoot.
Hope this helps?
Jun 28, 2017 | Garden
Dvd not play
A lot of the video screen units are on a lock down mode unless the parking brake is set on your car as a safety feature to make sure you are not watching while driving, there are ways to bi-pass this safety feature but do know it is illegal in some states. Trying YouTube for a way to bi-pass your safety feature sometimes its a lot easier than you would think.
May 01, 2011 | Kenwood KVT-512 Car DVD Player
Cant buy pass brake on my vm9311ts
use toggle switch on inout bypass code with remote
May 10, 2010 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
Parking brake safety bypass
here is what you need to do is, get a toggle switch and hook one side to a ground and the other side to the parking brake wire on the unit.
use the switch as a brake because you have to set brake for a few seconds then release and set again but keep it on this time.
you will have to do this every time you start the car.
Jun 26, 2009 | Dual Electronics XDVDN8190 GPS Receiver
Jensen vm9412 warning set parking brake to view viedo
what you can do is connect parking brake wire to the ground wire, that bypasses it and you will then be able to watch videos .
Jul 18, 2008 | Car Audio & Video
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Vm9312
That is the code for the older jensen's The parking brake bypass procedure is as follows: 1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
May 25, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
285 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
