Question about Vacuums
Won't **** up water - Vacuums
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=554095
Generic problem for all Vacuums
Won't **** up water
Posted by fusco7 on Apr 28, 2008
Won’t **** up water
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
We need more information like the brand name and model number to try to describe why it won’t pick up water, could be a clog, could be that the gasket is shot, the tank may not be sitting the vacuum correctly, and by giving the brand name I can direct you to the correct vacuum cleaner dealer or factory manufacturer so you can get this fixed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won't pick up water from the clean water side
I couldn't view u'r clip but it seems if the pipe is blocked try to remove the blockage by using a hose where you spray hot water and normal dishwashing liquid, through the pipe, to unblock it. Just do not immerse the whole machine in water! Because I do not know what machine you have. Good luck my friend!
Mar 23, 2013 | Vacuums
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
My steam cleaner is not spaying water on the carpet?
I found that if the water is not hot enough it won't create the suction needed for the water to spray. If you have use it in the past it could be that the water tubing could be clod.
Jul 21, 2011 | Bissell 1770 Quicksteamer II Upright...
Will not **** up
LOL.. not sure what it will not do.. but assuming it will not **** up the water ? make sure the dial is set to the correct setting. container for soap is full and correctly popped into place...
if the clean water resevoir is empty - it won;t **** up and if the dirty water resevoir is full it wont' **** up the water from the carpet... other than that... I don't know.
Mar 29, 2010 | Hoover F7431-900 SteamVac Vacuum
Won"t dispense water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
