Question about Miele W864 Front Load Washer
Miele novatronic w864 washing machine
Water left in fabric conditioner compartment when washing cycle has finished how can i solve this problem thanks
  • Anonymous Feb 10, 2009
    I have exactly the same problem which still remains after cleaning as suggested. Have run the machine empty on hottest programme as suggested by Miele technician lots of times but to no avail. Sometimes
    I am lucky and compartment does empty. I live in a hard water area and wonder if this could be a contributing factor.
  • Anonymous Feb 19, 2009
    I have the same problem even after cleaning the post. Any other ideas?
  • Miele Master
  • 744 Answers
Miele novatronic w864 washing machine.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 02, 2013
There will be a small qty of water left after the wash. However if the compartment is full then the syphon tube is probably blocked.
Lift the flap of conditioner compartment, you will see a round 'post' in the middle to the rear of it. Pull this gently off. Give it a thorough clean and also take whole soap draw to sink and rinse. Where you removed the 'post' flush through with hot water. Replace the post (will click into place).
You should now be good to go.
Posted on Sep 21, 2008
Fabric dispenser leaves water in dispenser after wash is done
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Jan 16, 2016 | Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Miele Novotronic T562C: Do I put the washing powder into the small opening/hole top left in the removable part? It looks almost too small! And I can't see how it gets out of there into the machine during a...
Right side of compartment for powder when Pre wash is selected.
Middle compartment for powder when Pre wash not selected
Left side with flap for fabric conditioner.
Apr 03, 2010 | Miele Novotronic Premier 500 Front Load...
Fabric conditioner still in compartment after wash
Most washers recommend dilluting the softener with water when you put it in the compartment. It can build up and completely block it. I've had to manually remove it with anything I could find to reach it and since I've started dilluting it have had not problem.
Aug 27, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Rinse cycle not kicking in
Make sure that the conditioner compartment is not clogged up with undesolved conditioner, remove and thoroughly claen all parts
To test the conditioner is going through, fill it with water to the top of the compartment until the water starts to run out, it should then continue to run out until the compartment is empty, if it does not , then it is still blocked.. Do this before you put it back in the washer.
This should solve the prob.
Plz rate my solution, and feel free to leave any comments.
Thanks.
Jan 02, 2009 | Washing Machines
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
My washer wont go past
put a new timer in it
Mar 24, 2008 | Washing Machines
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Miele W864 Front Load Washer Logo
571 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
