Question about Dell 924 All-in-One InkJet Printer
Dell A920 Printer
Have a broken ink hold down clamp. were can I find a replacement part? Thanks Terry
  • blarty Jan 19, 2009
    same thing. small plastic retaining clip has come off the printer ink cartridge clamp. seems to invite failure, actually. Dell does not come off very "green" in designing something so vulnerable which if it dies needs the printer replaced.
  • Anonymous May 15, 2009
    I have Dell A920 Printer Broken Ink Hold Clip Where Can Find This Part.
    Scholar:
  • 41 Answers
Hi ,
Dell will not sell the spare parts for the inkjet printers , if the printer is under warranty then call dell technical support and they will replace the printer
Posted on Apr 28, 2008
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 11, 2011 | Dell A920 InkJet Printer
    My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
    hi there !
    -try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
    cheers !
    Oct 24, 2009 | Dell A920 InkJet Printer
    DELL PRINTER A920 PRINTING IS BLOGGIE
    Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
    May 06, 2009 | Dell Inspiron 1000 Notebook
    Dell 920 printer won't print magenta.
    There are chances the magenta ink got over or its dried :
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer. try this if this did then heat the cart cartridges walls with hair dryer for 2 min then insert it back and check if it works:
    Feb 24, 2009 | Dell A920 InkJet Printer
    Flashing Green Light/ Computer can't communicate with printer......
    Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
    If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
    Hope this helps.
    Dec 14, 2006 | Dell A920 InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    121 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
