MY HP 2110 MODEL IN NOT PRINTING PROPERLY AFTER THE COLOR CARTRIDGE WAS REPLACED. The alignment seems to be stuck on please wait and nothing happens
    President:
  • 2,712 Answers
Hello ra78,
1.First, make sure that you have inserted the correct compatible colour cartridge for your printer properly and into the correct slot. You should hear an audible click when the cartridge is in place. Also make sure that you have removed the protective covering from behind the cartridge. Check to see that all contacts are clean. Alignment errors are generally due to incorrect placement of cartridges/defective cartridges/corrupt printer software.
2.Next, make sure you have the latest driver. You can download it HERE or HERE (This is the stripped down version).
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If, however it has not, then please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best as I can.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 28, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    More detailed and exhaustive solutions than can be typed here can be found on the HP website. Please click HERE.
    Hope that helps!
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything else I can assist you with...
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
    Genius:
  • 1,447 Answers
Clean the Nozzles
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 28, 2008
    The HP's have a little oval-shaped rubber 'do-hikey' that seals the
    area around the ink jets. It generally gets gummed up with dry ink, and
    does not seal completely anymore.
    Check and see if there is something similar that covers the print head when it is not in use.
    The "banding" can also occur as the cartridge starts getting towards
    the end of it's life. Also try cleaning the contact areas with a soft
    cloth. Poor contacts can cause similar problems.
    If large ink droplets are forming on the head during printing, this is a sign of poor contacts or a physically damaged head.
    However, most of the time it is caused by "clots" in the areas
    supplying the jets, or in the jets themselves. Sometimes soaking the
    jets in a tray of alcohol or water for a while can dissolve these
    "clots", but the success rate is not that great. Better to fix the root
    of the problem.
    BTW: Avoid turning the cartridge upside-down. Always hold it so
    gravity pulls the ink down to the jets and keeps them primed. Turning
    it upside-down can allow air to be drawn back into the jets.
    Sergeant:
    Champion:
  • 256 Answers
This new color cartridge you have replace...
  • 1 more comment
  • please clean your printer cartridge ones an try it.
  • Was this a new cartridge or did you re-fill? Make sure the cartridge
    was installed properly. Make sure you do not touch the copper contacts.
    If you did wipe GENTLY with alcohol. Did you remove the protective tape
    from the print nozzles?
  • Carefully set it in some hot water being careful not to get the
    contacts wet. When you see that ink is seeping from the cartridge wipe
    it of and try it again.
    Another method is to put a wet cloth in
    the microwave to get it hot and let the cartridge set on that until ink
    begins to seep. May require a couple of tries.
  • 655 Answers
On HP website you can find the how to aling your printer.
  • Iqbal Husain
    Iqbal Husain Apr 28, 2008
    There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
    • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
    • The paper has already been printed on or is colored paper.
    • Protective tape on a new ink cartridge has not been removed.
    • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
    • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
    • The ink cartridge is defective.
      Follow the steps below to resolve the problem:
    For more details Click Here
    Thanks
    Iqbal
My printer was in storage for a year, I now have it out and put new cartridges in it and it said it needed to align, so it printed out the aligning paper however it then said scanner failure and the...
Do the following:
a partial reset by pressing and holding Cancel and the Left Arrow while plugging in the power cord.
Wait 30 seconds (which was originally designed by help desks so the clients would calm down).
Hold down cancel and LEFT arrow buttons on HP 2110, while plugging the power to HP 2110.
Release the cancel and LEFT arrow buttons.
Nov 11, 2010 | HP PSC 2110 Color Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
Trying to complete alignment of new ink cartridge printer seems stuck on "aligning please wait"
Bypassing the Alignment
Press and hold the Setup, button, and then press Options (or Copy Options).
Nov 04, 2009 | HP PSC 2110 Color Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
Can't get the printer to print
Cycle power including unplugging AC cord from printer.
If you cannot copy (scan) after power on, the printer is bad.
You should be able to copy (scan) after printer is turned on and initializes (It will say "COPY / 100%").
Feb 18, 2008 | HP PSC 2110 Color Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
Hp 2110 All in One Printer
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Jul 29, 2007 | HP PSC 2110 All-In-One InkJet Printer
Scanner bar jammed by cartridge allignment
Any fix for this I have the same issue?
Dec 11, 2006 | HP PSC 2110 Color Printer
32 people viewed this question
k24674
jasbo
jasbo
