Question about Refrigerators
Thermostat replacement how do you remove the thermostat cover
  • thebluecube Aug 26, 2008
    FR158SE 1 Compact Refrigerator
    How do I remove the thermostat housing to repair/replace the thermostat.?
    There are no screws or obvious clips.
    Help please,
    Cheers.
    Thebluecube
  • Anonymous Feb 03, 2009
    I have a GE refrigerator model number: GSS25LGMA
    It is freezing everything even with it turned down to the lowest setting, I think its the thermostat...Can I replace this myself?
    Thank you!
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 28, 2008
2 Suggested Answers
  • 1462 Answers
SOURCE: How do I remove cover from fridge temperature control panel?
lever off the thermostat knob and you will often find fixing screws behind. also, fixing screws are often hidden behind little blanking plugs which lever out to expose the screw head
Posted on Jul 21, 2008
How to change the thermostat on 2000 buick park ave ultra
The thermostat is located under the cover that the upper radiator hose connects to on the engine, let engine cool and remove plastic cover over engine and then remove the 2 bolts that hold the thermostat cover down, replace the thermostat exactly as the old one came out, refill the system with the bleeder valve open on the top of the cover over the thermostat until coolant comes out as you fill, this bleeds our out.
Nov 05, 2012 | 2000 Buick Park Avenue
Tip
How to Change Thermostat in Acura Integra car?
1) First buy a new thermostat for you car year and model.
2) Then as per the procedure. Remove the radiator cap. Be careful that there will be pressure in the radiator. So just let the pressure release first before removing the cap completely.
3) The thermostat is connected to the black hose coming from radiator.
4) On the top of the engine there will be thermostat cover. The cover is fitted by two bolts on each side.
5) Then remove the hose connected to radio with the help of a pier.
6) The other end of the hose is connected at thermostat cover. Carefully remove the other end of the hose. A bit of coolant will flow from the hose while removing the hose.
7) Remove the screws holding the thermostat cover. Lift the cover after the screws are takes out. Then take the thermostat seated under the cover.
8) Remove the old gasket out from the thermostat with the help of knife.
9) Before removing the old thermostat carefully notice the position of old thermostat. In the same way place the new thermostat with the spring assembly in the down side of the engine.
10) Refit all the parts removed while removing the old thermostat properly.
11)After every thing is fitted proper as it was before, then check the coolant level if its low get it refilled till the required level.
This will help. Thanks.
on Mar 19, 2010 | Acura Integra Cars & Trucks
Want to know whats these codes mean [Engine rpn 704 rpm],[Map sensor 45 kpr], [cool ant temp 141f], [Dtc t caused rreezerrame p1281]. for a 2000 grand cherokee
Hi, the first part is data taken along with the code. The code P1281 indicates the engine is running cold (141 degrees--should be at least 190). Is your temp gage running lower than you are used to? If yes, it may be your thermostat has failed open. I have pasted below instructions for replacing the thermostat. Please let me know if you have any questions, and thanks for using FixYa.
3.7L & 4.7L Engines WARNING Do not loosen radiator drain **** with system hot and pressurized. Serious burns from coolant can occur.
NOTE Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse. If thermostat is being replaced, be sure that replacement is specified thermostat for vehicle model and engine type.
  1. Disconnect negative battery cable at battery.
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Remove splash shield.
  5. Remove lower radiator hose clamp and lower radiator hose at thermostat housing.
  6. Remove thermostat housing mounting bolts, thermostat housing and thermostat.
To install:
  1. Clean mating areas of timing chain cover and thermostat housing.
  2. Install thermostat (spring side down) into recessed machined groove on timing chain cover.
  3. Position thermostat housing on timing chain cover.
  4. Install two housing-to-timing chain cover bolts. Tighten bolts to 115 inch lbs. (13 Nm).
    CAUTION Housing must be tightened evenly and thermostat must be centered into recessed groove in timing chain cover. If not, it may result in a cracked housing, damaged timing chain cover threads or coolant leaks.
  5. Install lower radiator hose on thermostat housing.
  6. Install splash shield.
  7. Lower vehicle.
  8. Fill cooling system.
  9. Connect negative battery cable to battery.
  10. Start and warm the engine. Check for leaks.
Removal & Installation, 4.0 liter engine
  1. Disconnect the negative battery cable.
  2. If necessary, disconnect the coolant temperature sensor electrical connector.
  3. Disconnect the upper radiator hose from the thermostat housing.
  4. Remove the attaching bolts and lift the housing from the engine.
Remove the thermostat and gasket.
To install:
  1. Clean all gasket surfaces thoroughly.
  2. Place the thermostat in the housing with the spring inside the engine.
  3. Install a new gasket with a small amount of sealing compound applied to both sides.
  4. Install the water outlet and tighten the mounting bolts to 200 inch lbs. (23 Nm) on V-8 engines and 15 ft. lbs. (20 Nm) on non-8 cylinder engines.
  5. Install the upper radiator hose to the housing and tighten the hose clamp.
  6. Connect the coolant temperature sensor connector to the housing.
  7. Refill the cooling system.
Apr 13, 2011 | 2000 Jeep Grand Cherokee
Replacing a thermostat on 2004 nissan sentra
  • Prepare for the replacement by disconnecting the negative battery cable and draining the engine coolant into a container--you need to remove the drain plug from the radiator first and then the drain plug at the engine block.
  • Remove the engine's cooling fan by loosening the fan/water pump pulley nuts, unclipping and removing the fan shroud's lower half, removing the water pump pulley nuts and pulling the fan out from underneath.
    Disconnect all components blocking access to the thermostat by removing their bolts. On four-cylinder engines, this includes the air cleaner, air intake duct and the power steering pump's support bracket. On a 3.3 liter V6 or SOHC engine, remove the upper radiator hose from the intake manifold's coolant outlet.
  • Slip off the drive belts blocking the thermostat by turning their tensioner bolts with a wrench or breaker bar. On a 3.3 liter truck or DOHC engine, follow this by removing the upper idler pulley bracket. On a 3.5 liter engine, remove the water pump drain plug from the front end of the block.
  • Detach all hoses from the thermostat housing cover by loosening the hose clamps with pliers; this usually includes the lower radiator hose. This is only needed on V6 engines; you will keep the hose attached on a four-cylinder.
  • Remove the thermostat housing cover by removing its bolts. There will be some coolant spilling out when the gasket seal breaks.
  • Disconnect and remove the thermostat from its cover by removing its screws. Take note of how the thermostat is positioned within the cover.
  • Scrape away all traces of gasket or sealant from the housing and cover and clean the surfaces with lacquer thinner.
  • Apply RTV sealant around the edge of the thermostat cover. You need to re-install the cover within five minutes of applying this sealant.
  • Mount the new thermostat into the cover in the same position the old thermostat was in.
  • Re-install the thermostat cover and all other parts in reverse order of installation.
  • Wait a half hour for the RTV sealant to cure before refilling the engine coolant. Use fresh coolant if the old coolant is contaminated.
  • Mar 20, 2011 | Nissan Sentra Cars & Trucks
    Where is thermostat on my 2005 chevy classic
    Thermostat Removal & Installation 2.2L Engine 2004-2005 To Remove:
    2. Remove the thermostat housing-to-water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    3. Remove the water pump feed pipe from the thermostat housing .
    4. Remove the thermostat from the housing.
    To Install:
    1. Install the thermostat on the housing.
    2. Install the water pump feed pipe on the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
    3. Fill the cooling system.
    2006-2007 To Remove:
    1. Drain the cooling system.
    2. Disconnect the radiator outlet hose from the surge tank and thermostat housing cover. Thermostat & cover gm-03-39-3601.gif
    3. Remove the mounting bolts and remove the thermostat housing cover.
    4. Remove the thermostat from the housing. Discard the O-ring.
    To Install:
    1. Using a new O-ring, install the thermostat on the housing.
    2. Install the thermostat housing cover with the mounting bolts. Tighten 89 in-lb (10 Nm).
    3. Connect the radiator outlet hose to the surge tank and thermostat housing cover.
    4. Fill the cooling system.
    3.5L Engine (LZ4) W/ Variable Valve Timing & 3.9L Engine To Remove:
    2. Remove the air cleaner outlet duct.
    3. Disconnect the radiator outlet hose from the thermostat housing. Thermostat 3.9L gm-03-00-3054.gif
    4. Remove the mounting bolt/stud and remove the thermostat housing.
    5. Remove the thermostat from the engine.
    6. Clean the sealing surfaces.
    To Install:
    1. Using a new gasket, install the thermostat on the engine.
    2. Install the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
    3. Connect the radiator outlet hose to the thermostat housing.
    4. Install the air cleaner outlet duct.
    5. Fill the cooling system.
    6. Check the cooling system for leaks.
    3.5L Engine (LX9) W/O Variable Valve Timing To Remove:
    1. Drain the coolant.
    2. Disconnect the radiator hose from the thermostat housing. Thermostat 3.5L gm_mv_ven_tstat.gif
    3. Remove the mounting bolt/stud and remove the thermostat housing.
    4. Remove the housing gasket.
    5. Remove the thermostat.
    6. Clean the mating surfaces.
    To Install:
    1. Install the thermostat on the engine.
    2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
    3. Connect the radiator hose to the thermostat housing.
    5. Check the cooling system for leaks.
    Jan 29, 2011 | 2005 Chevrolet Malibu
    How do i replace the thermostat
    Follow this steps on how you can replace the thermostat. First,Remove the radiator hose from the thermostat housing cover by removing the bandclamp that holds the hose to the cover. This is done with a Phillipsscrewdriver. Slide the band clamp back away from the housing and pull the hoseoff. Remove the two bolts that hold the thermostat housing cover to the top ofthe Elantra intake manifold with an adjustable wrench. The bolts will bereused. They should not be discarded. Remove the old gasket that was pressed between the intake manifoldand the thermostat housing cover. It's a paper gasket and should pull off ofthe intake in one piece. Remove the thermostat from inside of the intakemanifold by pulling up on it. The gasket and thermostat can be discarded. Placethe new thermostat into the intake manifold of the Hyundai Elantra. Thethermostat must be placed with the top sticking out of the intake manifold forit to work properly. Use the old thermostat to orientate the new one. Place a small amount of PVC gasket sealer around the thermostat onthe base of the intake manifold. Allow the PVC to dry for ten minutes and thenplace the thermostat gasket on top of the gasket sealer. Place a small amountof PVC gasket sealer on top of the paper gasket and allow to dry for tenminutes. Place the thermostat housing cover onto the gasket and bolt it intoplace with the original bolts. You should see a small amount of PVC gasketsealer squeeze out between the housing and the intake. This is normal and itshould be left in place. Once it dries, it will add additional seal protectionand prevent leaking. Place the radiator hose back on to the thermostat housing cover andfix it into place by tightening the band clamp with a screw driver. YourHyundai Elantra is now ready to drive again. Hope this info help you.
    Jan 25, 2011 | 2005 Hyundai Elantra
    Need instructions for replacing thermostat on a 2001 Grand Cherokee 4.7 litre
    Instructions
    1. Locate the Cherokee's thermostat intake housing by following the top radiator hose to the engine. The hose connects to the thermostat intake. A second, smaller hose connects to the left side of the radiator hose. This is a bypass hose for the heater.
    2. Remove the two bolts that secure the Cherokee's thermostat intake housing to the engine with a socket and ratchet and lift the intake upward to drain the coolant in the hose back into the radiator.
    3. Remove the gasket and the thermostat from the engine and discard them. Wipe the mating surfaces of the thermostat intake housing and the engine off with a clean towel.
    4. Place the new thermostat, spring down, into the engine and place the thermostat gasket over the thermostat.
    5. Place the thermostat intake housing onto the thermostat gasket. Thread the bolts into the thermostat intake by hand to avoid cross-threading the bolts and then tighten them using a socket and ratchet.
    Additional information:
    7. Lower vehicle.
    Good Luck and if this helps don't forget to vote.
    Jan 15, 2011 | 2001 Jeep Grand Cherokee
    I need to replace a thermostat in a 2000 Chevy 2500 6.0 liter pickup
    4.8L, 5.3L and 6.0L Engines To Remove:
    CAUTION
    The thermostat is not serviceable separately. The thermostat housing (water pump inlet) and thermostat must be replaced as an assembly.
    2. Remove the bolts from water pump inlet.
    3. Remove the water pump inlet from the water pump.
    To Install:
    1. Install the water pump inlet to the water pump.
    2. Install the water pump inlet bolts.
      • Torque to: 11 ft-lbs. (15 Nm)
    3. Install the radiator outlet hose.
    6.6L Engine To Remove:
    1. Before servicing the vehicle refer to the precautions at the beginning of this section.
    2. Drain the engine coolant.
    3. Remove or disconnect the following:
      • Water outlet 6.6L Thermostat housing removal gm_trk_sil25_02-04_66_therm_hous_rem.gif
      • Bolt for the fuel line bracket
      • Thermostat housing cover bolts
      • Thermostats and seals
    To Install:
    1. Install or connect the following:
      • Thermostats and seals to the thermostat housing NOTE: The rear thermostat (D) has 2 vent valves. Install with the vent valves towards the rear of engine.
      • Thermostat housing cover with a NEW gasket
      • Thermostat housing cover bolts and tighten the bolts
        1. Torque to: 15 ft. lbs. (21 Nm)
      • Fuel line bracket bolt and tighten the bolt
      • Water outlet
    2. Fill the engine with coolant.
    3. Test drive the vehicle to confirm the repairs.
    8.1L Engine To Remove:
    2. Drain the cooling system.
      • Inlet hose from the water outlet Water outlet and thermostat removal chevy_sub25_02-04_60_thermost_rem.gif
      • Water outlet bolts (B)
      • Water outlet (A)
      • Thermostat (C)
    To Install:
      • Thermostat
      • Water outlet
      • Water outlet bolts and tighten the bolts.
        1. Torque to: 22 ft-lbs (30 Nm)
      • Inlet hose to the water outlet
    2. Fill the cooling system.
    Jan 12, 2011 | 2000 Chevrolet 2500
    How to replace thermostat
    The thermostat is located behind the thermostat housing on which the ECT is installed.It is attached to the lower radiator hose. Remove the lower radiator hose and the housing attached to it you would get the thermostat.To replace the thermostat, you must remove the air cleaner box, remove the thermostat housing cover, replace the thermostat with a new gasket, clean off any old gasket material, reinstall the housing cover and air box, and then fill and bleed the cooling system.
    Thank you !!
    Jul 07, 2010 | 2004 Hyundai Elantra
    How to remove thermostat cover to replace
    the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
    May 15, 2009 | Honeywell Programmable Thermostat Heater
    Refrigerators Logo
    664 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
