Question about Eddie Bauer 3-In-1 with Latch
How to recline 3 in 1
The car seat is very secure front to back, but will move side to side at the bottom. I think my problem is the recline..I can't figure out how to do it. I have pulled the red latch...what else do I have to do. Does it recline while installed or do I need to totally start from scratch?
THANKS!
I suggest you recline it before you put it in the car.
Posted on May 22, 2008
2004 honda accord drivers power seat stuck in the down position.
Could be defective adjustment switches rather than motor
Oct 10, 2016 | 2004 Honda Accord
Graco Super Seville Pushchair How do I adjust the 3 postition seat
Hi there
At the back of the seat is a metal bar, pull that up and pull the seat back.
I've found with mine that if the handle is one of the two positions (can't remember which, I think it's for forward facing pushchair) you can't recline it at all. I have to move the handle the other way first then recline it.
To move the handle there are two button/levers, one on each side. Lift those up and the handle will move, make sure it then clicks into place.
Hope that helps
Aug 09, 2011 | Computers & Internet
Driver seat removal 1993 lexus gs 300
put the seat in the full back position remove the two front bolts securing it to the floor, move it all the way forward now, remove the two rear bolts securing it to the floor now tip the seat back allowing it to rest on the back seat. make sure there is no additional wiring plugged in. use the recline function the make the seat flatter, now with two people roll the seat and remove throught the front door utilizing the rear for the helper
Feb 27, 2011 | Lexus GS 300 Cars & Trucks
I do not know how to remove front seat from a 1994 chevrolet beretta cp
hmm,, ok,, try this..
1.) look under the seat you will notice two sliding rods,, on this there are 4 brackets with bolts.. its maybe hidden under the upholestry,, any way remove the bolts,, slide any lift seat..
Oct 12, 2010 | Chevrolet Beretta Cars & Trucks
My maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Jan 03, 2010 | Baby Gear
CAN YOU MANUALLY RECLINE A POWER SEAT THAT IS STUCK
only 4 bolts hold the seat in they may have a plastic cover on them that can be popped off with a screwdriver.remove the bolts and lean the seat back check the wires going to the motor and make sure it has power going to it.Don't know of any way to manually recline the seat without taking it apart.
Jun 07, 2009 | 2002 Nissan Maxima
Power front seat will move forward but not back, kia sedona 05
it sounds like the one side of the switch has went bad it will need replaced you can do yourself it is a fairly easy task
May 04, 2009 | 2002 GMC Envoy
2001 Nissan Altima - Seat Back stuck in the recline position.
where is the overload protection circuit for power seat of nissan altima 2001 , the seat does not move back and front let me know if i could do the seat move
Jan 18, 2009 | 2001 Nissan Altima
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Eddie Bauer 3-In-1 with Latch Logo
186 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
