Question about Samsung YP-K3 MP3 Player
Cant detect as portable device
Cant detect computer and come up as a removable drive used on couple of laptops also can detect as portable device on media studio can anyone help or is my unit faulty
  • pfranco1 May 04, 2008
    my computer can´t find the divice
  • kukri Jun 27, 2008
    Cannot copy :The device has either stopped responding or has been disconnected.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
My external hard disk cant initialized
Try it on the rear ports on your motherboard if it is usb. Make sure the cable is a good onem try exchanging for another. For a device th intioalise drivers should be necessary, does it come with any, which operating system are you using. Have you tested it on another computer to check that it is functioning? There are lots of things to check
Also, before you do anything else, ensure that all usb support is enabled in bios.
Jun 10, 2015 | Western Digital 1TB My Passport Essential...
Pqi h551
Most of the behavior occurs when the laptop with battery or the computer can not supply the stable power. The problem is often resulted from connecting lots of USB devices at the same time. Because most of USB device use the power supply from computer, it leads to the insufficient power supply of computer. Please make sure that the computer supplies stable power. You may connect the power cable if you use laptop. Moreover, we suggest you removing the other unnecessary USB device.
Mar 19, 2014 | Computers & Internet
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 01, 2013 | Transcend USA 120GB Storejet 2.5" SATA -...
Cant find disk to boot
Mar 25, 2013 | Acer Aspire S7 ultrabook
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
What's your cant access my c drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 05, 2011 | Acer Aspire Z5600 PC Desktop
I connect the USB 3.0 portable hard drive for Iomega its not working in my computer but i connect another computer its working tell me solution
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
WD passpert hard drive 750gb cant be detected on my laptop or on any other laptop ???
It may not be detected because you may have another device using the default drive letter that the portable drive want sto use. Try going into your computers manage console and see if it is there. If you need help with that let me know what type of operating system you have (XP, Vista, 7.
Nov 08, 2010 | Computers & Internet
Samsung YP-K3 MP3 Player Logo
63 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
