Washer won't drain i haven't opened the back panel yet (top loading frigidaire FWX833AS1.) before i open the back panel, I'd like to know how to clean the drain pump. (the washing machine is full of water now, too.) eeeeek thanks! i'd really like to solve this problem myself, even though i'm not known for appliance repair. by the way...i can force the cycle to go to the final spin...but the water is still stuck in tub. all clues point to a clogged drain pump. thanks for any help!
I was having very much the same issue. My washer wouldn't drain (wouldn't go into the fast spin to initiate drain).
My husband followed Fixums instructions for removing the front panel of the washing machine.
He used a shop vac to empty the washer and also to **** any debris out of the drain tube.
What ultimately ended up working was removing the pump and finding out that there was lint (as well as a quarter from someones pocket) blocking the pumps flow.
He removed all the blockages and put the pump back in - everything is working like a charm now!!!! Spins, rinses and empties properly again! Good for another 100,00 loads!! =)
Posted on Mar 08, 2009
    Genius:
  • 1,073 Answers
Remove the fount panel it is held in place with 2 phillips screws located ant the bottom of the frount panel,
use a putty knife and locate the top holding clips push in with the putty knife and lift up on one side of the top repeat for the other side
once the top is lifted up push down on the frount panel and it will come off
pump on the right side check drain pipe for blockage also while checking pump
naturally drain the tub if you have a wet dry vac fastest way
Posted on Apr 28, 2008
The door lock won't open. I unplugged unit to reset, but still can't open door.
try finding the manual release..on my bosch nexxt 300 there is an access panel on front lower right of unit for the drain if i open it and reach up there is a cable to pull on to manually unluck the door...have wet vac ready as there might be water from a clogged drain causeing washer to keep door locked
Oct 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Describe your 24032 \ 24036 Top Load Washer Problem changed the motor coupler and now the motor won't work. washer fills up but won't agitate or spin or drain
Sounds as if your lid switch is open. You can by pas it under the control panel on the right in the back it is a the wire plug. Connect the black and brown on the switch side which will allow you to just plug a new one when or if you deciced you needed this "safety" feature. Do not put any part of your body in machine while spinning. Your welcome, Masta tech.
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Frigidare FWX833AS1 which had been working quite well until a screw left in a pants pocket lodged in the basket/drum. after that it hasnt drained completely but running the spin cycle a second...
Take off the back of the machine. Locate the water pump, it will have the drain hose attached to it. Remove the water pump and take it apart. You should find your screw and maybe some other things. If the water pump is not damaged reinstall and everything should be working.
May 31, 2011 | Kenmore 24032\24036 Top Load Washer
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
No cold water
the most common failure for that would be the cold water side of the inlet valve. To be sure you would need to access the valve and test the leads to make sure you have 120V at the valve,if you do then replace the valve
Feb 19, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire Gallery trouble
Took off the front panel, opened up the hoses to the pump, found a small metal magnet from my son's pocket that had been stuck in the pump. Once it was removed, the washer worked just fine.
Nov 05, 2008 | Frigidaire GLWS1233A Top Load Washer
Frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
4.Will not drain and displays F/02
The error code F/02 will be displayed if the drain time exceeds 8 minutes. Press pause/cancel twice to remove display. Check the pump filter and wiring connections on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
Oct 19, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire top loading washer, fwx833as1
YOUR BEARING ARE GOING BAD ,MINE DOES THE SAME THING,THANKS -MIKE
Jul 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
294 people viewed this question
Top Washing Machines Experts
