Question about JVC Audio Players & Recorders
No sound from my JVC MX-C330 Stereo Hi I have a JVC MX-C330 stereo that after a period of non use has stopped working. The problem is that there is no sound coming out of the speakers, although the CD player, radio and cassette decks all appear to be functioning properly - just an annoying lack of sound! Any ideas would be much appreciated. Cheers
  • 55 Answers
SOURCE: stereo speakers stopped working
the ''watts'' are peak or rms?notice that 150 Wpeak are about 70Wrms....
Also notice if you are using ''big'' speakers you can burn your amplifier..
Posted on Nov 18, 2007
jack_daniels
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
  • 4 Answers
SOURCE: much loved old J.V.C. unit
try turning it upside down and pluging in and out while turning it on.
Posted on Dec 19, 2008
SOURCE: Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Posted on Jan 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
My jvc mx-kc58 compact shelf stereo the aux in mode sounds far away an i can barely hear the words in aux mode only cd player sounds normal
It sounds like whatever is connected to the aux socket has a bad earth connection check and replace the cables to it.
Dec 23, 2016 | JVC MX-KC58 Shelf System
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
I have an old JVC stereo model number MX-D301T. There are two issues with my stereo. First, the volume wheel has stopped working. It is stuck on the highest volume setting and does not change when the...
The volume is probably controlled by an IC that does all the work. It most likely has failed. It's unlikely that the wheel is the cause of the trouble, unless it has broken leaving the circuit fully open. But I think that unlikely.
If the unit has not been used for sometime then the second fault will probably due to the belts turning to goo!
Oct 01, 2017 | JVC MX-D301T Shelf System
I have a jvc mx-c330 bookshelf home stereo in the middle of listening to music the band e.q. changes on its own. do i need to set something as far as memory or what .
There is a demo button. When it's plugged in the first time, or with a power loss, it reverts to that mode. Hit the demo button and it goes away. =)
Feb 03, 2011 | JVC Audio Players & Recorders
JVC MX-J200 CD Shelf System vs young boy and a penny
Coins are metal, and so this piece of metal could have come into contact with the circuit at any point, causing a short circuit. General this would have blown the fuse inside the unit. So start looking for a fuse. On the PC board it could be marked with a letter "F".
May 18, 2017 | JVC MX-J200 CD Shelf System
114 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
