Question about Mintek DTV-233 23 in. TV/DVD Combo
Toshiba tv/dvd combo
I have a disc stuck inside the player, I have pushed the eject button one hundred times, on both the tv and the remote.  It won't eject...  It will still play the movie again, too bad it's the worst movie ever...  I have also tried unplugging it and fishing around inside with a tweezer.  I don't think that will work, it's too small to see anything inside.
  • tressand Apr 28, 2008
    I actually got it out.  I don't think there's a small hole on this one, it's just a slot on the side of the tv with felt around it...  I taped back the felt so i could see inside, and noticed it was the things holding the dvd in place that was the problem.  So I pushed on that thing while pressing eject and it spit out the dvd finally.
  • adb9 Apr 08, 2009
    How did you push the things holding the DVD in place?
    I have the same thing going on with our Toshiba. It is the two metal "things" that are not retracting and allowing the DVD to eject.
    Genius:
  • 1,554 Answers
Is there a tiny little hole you can insert a paperclip into around the front of the cd.
if so use a large one if you have it , insert and press hard to eject.
if not then you will need help.
even if you get it out the eject motor belt is likely slipped or broken.
Posted on Apr 28, 2008
Does anyone know the numeric code to unlock the DVD tray inside this Toshiba 19LV61K TV/DVD? There is a disc stuck inside the DVD tray, and the film will play without a problem.
There is no such code to get out the strucked disc. you have to take out it by manual method. If you wish to get some details; check the site linked here. Pull up older posts.
If you insist on a numerical code, and have determined, won't do anything without it, try this alpha numerical code {VWXTB 028103820489} Followed by Menu button.
Good luck.
Mar 24, 2016 | Toshiba Televison & Video
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
Disc will not eject from dvd player
Have you tried both the eject button on the DVD drive and the remote? Is there a disk jammed in the drive? Here is the manual:
http://www.curtisint.com/html/custservice/manuals/PRO_PLEDV1945A_EN.PDF
most of the time there is a small hole near the eject button that you can unbend a paper clip and insert it into that will release the door.
here's a video.. it's a computer, but same principle:
Open Stuck Drive on Your PC
Aug 14, 2015 | Curtis ProScan PLEDV1945A 19"" TV/DVD...
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Magnavox DVD eject button fell in TV
Take a close look where the plastic button was--it if there would engage a tiny round black rubber like button---using a pencil eraser see if you can gently push the button.
Jun 13, 2012 | Philips Magnavox 20MC4204 20 in. TV/DVD...
My Toshiba VCR & DVD video recorder model D-VR4XSU won't eject a DVD disc from the player, neither by pressing the eject button on the remote nor by the eject button on the players console.
A temporary solution would be to use a paperclip to eject it; usually, any disk drive has a little hole that a paperclip can be stuck into which forces it to eject.
Mar 04, 2011 | Toshiba Televison & Video
Have a Toshiba hlv87 tv/dvd combo that will not eject a good dvd
I've had the same problem. I called Toshiba support and all they could say was to unplug it. Since I already had done that, they were going to send a service person over for a couple hundred bucks (which they get a cut of) to take it apart. Haa
Aug 02, 2010 | Mintek LCD TV Progressive Scan DVD Player
Have a vcr/dvd combo. The door will not open on dvd player.
A disc may be stuck inside it, preventing it from opening. You may have to remove the housing on the unit and look inside the dvd area to see if there is something stuck. It could also be broken or not getting power. Try unplugging it for a few minutes than trying it again, as well as holding down the eject button for a few seconds. Be patient after each button press, as the player is programmed to stop the disc and "park" the laser before ejecting.
Hope this helps!
Jan 05, 2010 | Toshiba Televison & Video
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
DVD DISC STUCK IN TV'S DVD PLAYER
It is usually a complete unit mounted inside.Don't stick anything in the slot to try to get it out.You'll end up damaging the unit and have to replace it.If you are mechanical,then you can remove the unit.Take the cover off,then manually eject the disc.That means finding the small motor that runs the mechanics and turning it by hand.Very slow process,but if your patient and take your time to get the disc out , then reinstall it and it will reset itself and should be ok.
Nov 18, 2007 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Mintek DTV-233 23 in. TV/DVD Combo Logo
367 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
