NEED INTERNET CONNECTION TO ROUTER DI-514 - Computers & Internet
    Scholar:
  • 154 Answers
Check this :
http://support.dlink.com/products/view.asp?productid=DI%2D514
there might be a solution to your problem
Posted on Apr 28, 2008
I have connection but can't browse.
You have a connection to the router or a connection to the internet? There is a difference.
Aug 01, 2013 | D-Link DI 514 Wireless Router (DI-514)
Have internet on main PC but cannot get connection for laptop Using D-Link 514
Is this a wireless connection? Make certain the router is transmit is turn ON and on high power. Make certain your laptop WiFi is turned on. Use the network connection to connector to the router.
Jul 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Can't get internet connection
Plug your broadband connection to router'e broadband port and check your router's are getting automatic IP address or not, if not then need to feed manual IP address in your router which one provided by your ISP.
Mar 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
Ran the setup wizard for the d link di 514 but still cant connect to internet
Do you have Internet connection before you installed the Dlink router? Do you have cable or DSL? If you have DSL make sure you have the username and password from your Internet service provider because you need to enter those information when you run the set up wizard. You need to connect your computer to the LAN port of the router. Turn off computer and router, turn on router first then turn on the computer. Run the set up wizard again.
http://technicalsupport.blog.friendster.com
Sep 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can't connect to the internet when using DI-514
First check if your modem is properly with router and if your computer is properly connected with the right port in the router. You must configure it to work with your Internet Provider. For Cable company you need to configure the router as Dynamic IP and for DSL users it needs to be configured as PPPoE connection.
Apr 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using 192.168.0.1. User name is admin and leave the password empty then run the wizard.
May 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
