Question about Refrigerators
Our ice tastes and smells like mildew or mold.....
  • 1 more comment
  • fxst Jan 01, 2009
    The water coming out of the door tastes and smells fine but the ice smells AWFUL. I removed the ice bin to clean it and it still smells. It seems that the plastic and metal are retaining the smell. Any ideas???
  • dorispoz Jan 04, 2009
    My ice seems to be ok when it is in water, but when put in soda or any other liquid it smells like rotten eggs. I have public water and my house is only 4 yr old. Where can I get this odor filter for the main line?
  • kathy0777 May 02, 2009
    water and ice taste and smell like mold or mildew
    Genius:
  • 1,073 Answers
Install an odoer filter on the fridges main water line
Posted on Apr 28, 2008
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
I have had my Pelonis water cooler for approx 2 years now the cold water tastes like mildew. I tried cleaning it with a product from Culligan but the problem seems worse. Any suggestions
I would suggest a 50/50 mix of water and bleech, and make sure you let it soak long enough to kill the germs. Then flush is well with plenty of water.
Jan 02, 2012 | Refrigerators
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Foul smell coming from behind the refrigerator. I smell it coming through the fan on the back of the refrigerator. I believe it could be the drip pan, but I don't know where it is located. Also, my...
the drip pan is usually on top of the compressor or has a draw underneath with a coil to create heat for evaporation of water from the drip pan. Some time a rodent can drown in this location.
Jul 17, 2017 | Whirlpool GB2SHDXP Bottom Freezer...
Our new maytag fridge makes the worst tasting ice. What is the problem??? Model # MBF2258WEWO
Are you using plastic or copper tubing for the water lines. I was never a big fan of plactic because it tends to trap mold and mildew.
Nov 29, 2010 | Maytag Refrigerators
Awful smell! I drain it every cycle, I use the washer cleaner, everything! I am so sick of my towels smelling awful.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Mar 24, 2010 | LG WM-2277HW Front Load Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Ice in my ge frigerator smells and tastes like mold,in the fridge
I would suggest changing the plastic feeder tubing to the filter and the ice maker on the unit. Also, the ice maker units unplug and can be removed quite easily, you can also take that out and give it a thorough cleaning with warm soapy water, being a careful not to get water on any electrical parts.
Jun 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerators Logo
591 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
