Question about RCA M2000 MP3 Player
M202e player can this player be connected to your car stereo if you have an aux port in your car?
Yes, usually this unit comes with a fm transmitter, just pick up the signal from that from your raido then you are good to go, you cam also use 3.5 m jack to 3.5 m jack to connect it via sa cd player input on the car, I hope that answers your question.
Posted on May 19, 2008
Can this be connected to the aux port of a car radio? how via USB or ear bud jsck?
Usually If the car has an existing audio jack port you should be able to use an audio cord that has a male audio jack on both ends and it should work. Just make sure your on the right output selection on the car stereo. (Such as aux, cd, tuner,)
Apr 01, 2015 | Mach Speed Trio Clip MP3 Player
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
How can I hook my Sandisk Sansa Clip+ up to my stereo system if the stereo doesn't have a USB port?
Connect a audio from the headphone socket on the player and plug it into the AUX input on the stereo system. Set the stereo to AUX, turn on the player and adjust the volume level on the stereo.
Nov 28, 2012 | SanDisk Sansa Clip MP3 Player
Cable Connect iPod iPhone MP3 Phone Audio to Mazda Car Player
Does your car player have a auxillary jack (looks like headphone hole)
or does it just have a tape player?
if it has an auxilary plug then you need to plug the cable from your ipod into that and set the stereo to aux for source.
if the car has a tape player go to the store and ask for the cassette that plugs into your headphone jack. then you can put that tape into the tapeplayer and plug the other end in your headphone port on the ipod and listen away
Oct 04, 2012 | Elandpower Aux 3.5mm Cable Connect Ipod...
Where is the auxiliary port in a 2000 Jimmy? It has an aux button but I don't know where the jack is??
hi,
If the car audio player have AUX input selction then there will be a port (stereo RCA) behind the player. Will be named as AUX IN.
ok
Sep 11, 2011 | Car Audio & Video
How to transfer the songs to car player
Do you mean play songs through your car player, because Car stereos do not have storage devices. They usually have a CD player and radio.
If you Car Stereo has a Aux in port in the front or back you can connect the Sony Media player by buying a 3.5mm jack to 3.5mm jack cable as shown below.bobhifi_45.jpg
May 02, 2011 | Sony Walkman NWZ-E344 Digital Media Player
How do you fix a cd player on a stereo
Usually fixing CD players on stereoare quite simple and depends on the stereo in question. First you have to check if the stereo has a space for auxiliary port at the back it is usually denoted by AUX if it doesthen the operation is possible. All you have to do is get one of two types of cables depending on what type of CD player. If it is a walkman then you get the cable with Single 3mm earphone jacks to double av. If on the other hand the cd player has the av jack output then you get the normal av cable. connect from the output of cd player to aux of stereo then change the stereo function to aux.
hope this solution has been helpful?
Jan 01, 2011 | Venturer CD2315 Shelf System
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
M202e
I use mine in the car, but i run one of those tape player adapters to the headphone jack of the rca.
Apr 28, 2008 | RCA M2000 MP3 Player
Aux wire?
Your query > ..."wire...to hook...mp3 player ...RCA RS2044 stereo..."
You need to connect the headset out of your MP3 player using a special cable to theInterfaces/Ports: AUX-in of the RCA RS2044.
One of the many technical name for the special cable is RCA Male Stereo to male baby phone stereo, the common name is MP3 to RCA and it is similar to the function and look of a Cygnett Groove Transit - MP3 Phone to R...
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 29, 2007 | RCA RS2044 Shelf System
Open Questions:
RCA M2000 MP3 Player Logo
63 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
