Belkin Wireless-N Wireless Router with 4-Port Switch F5D8233-4
For this router, is the LAN connection different from what is used in most households? I ask because most of the other routers say "Wireless" under the LAN heading, but this Belkin only says "Ethernet." Does this mean it won't work with the normal Time Warner-type cable setup?
  • 56 Answers
It will work just fine, I had the same info display when I was w/ Time warner.
Posted on Apr 29, 2008
I have a Belkin N wireless router. It's all set up but it shows as not being secured. How do I secure it? Model F5D8233-4v3
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 08, 2013 | Belkin Computers & Internet
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Feb 12, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin F5D8233-4v3 router. I can get just one wired port to work. I use both wireless and wired connections. Could this be a hardware or software problem?
That's a fairly new router, you shouldn't be having those issues. Make sure you're identifying the uplink port, the quickstart guide with router should help with that.
If everything is wired correctly, it could be either firmware of hardware. Might want to try calling Belkin or even where you bought it from to see if you can exchange. Sounds like you got a defective unit. Alternately, try going to Belkin's website and downloading and installing the latest firmware for the router. If that doesn't do it, then you have a hardware failure, and Belkin should owe you a new router, that router claims a lifetime warranty.
There is a new firmware v4, sounds like you have v3, check here:
http://en-us-support.belkin.com/app/answers/detail/a_id/521/kw/F5D8233/r_id/166
Feb 04, 2010 | Belkin Computers & Internet
I have a different laptop and I can't seem to get this one to pick up the wireless connection. It is a wireless laptop. XP is loaded on it. My Belkin router is . We had a password on it but had to take it...
1. please chk if you might have a wireless switch to enable wireless in your laptop 2. Let your computer scan for wirelss networks and see if you can see the network in the list. 3. If you dont see it in the list, go closer to the router so the signals are better 4.If you still dont see it, try to reboot the router once. 5. If you see it and not connecting, please chk if you have a mac address filtering on the router. this is probably not letting you in now.
Hope this helps Ranjit
Sep 13, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin F5D8233 keeps dropping connection
hi
plz give a static ip on the comp under w/l n/w connection in the router's ip range.
Gud luck
Thanx and regards
Sukhiii
Jul 22, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin N Wireless Router - wireless light no longer lit up
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Jul 02, 2009 | Belkin Wireless-N Wireless Router with...
Installation
User manual: http://www.belkin.com/support/article/?lid=en&pid=F5D8233-4&aid=8340&scid=942
Don't forget to make a WPA key to secure your network. (WPA is stronger than WEP encryption) also AES is stronger than TKIP.
Other than that you should just plugin your WAN (modem) to the router in the specified port and then plugin any wired connections, if you don't have any you need to use the wireless connection and connect to your router and set it up that way.
The setup address should be 192.168.0.1, or 192.168.1.1, or it maybe be different, in that case go to start>run>type cmd and then type in ipconfig in the command prompt, and the gateway address is the one that is the router setup IP. Enter that into your web browser (if the first 2 don't work, use the cmd/ipconfig method to findout the gateway address.)
After that you can refer to the manual since I dont have the same router.
Sorry if thats not enough help!
Feb 27, 2009 | Belkin Wireless-N Wireless Router with...
Cannot connect Belkin F5D8233-4 Router to Mac Laptop
If you tell me the version number of your Belkin wireless router , i can fix this issue.Any Routers issue contact me,, i can help you out. copy and paste this address to Browse,Mentioned below http://techhobbies.blogspot.com
Jan 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Using 2 routers
You may use your wireless router as an Access Point:
1. Connect one of the LAN port of the Belkin to a LAN port on your Voyager. If the link light on both side are not coming on, try using a cross-over cable. Important: Do not connect anything to the WAN port of your Belkin.
2. Configure the LAN IP address of your Belkin in the same subnet as the Voyager. By example, if your Voyager has 192.168.0.1, you may give your Belkin 192.168.0.3.
3. Disable the DHCP server on the Belkin since the Voyager most likely already has one.
4. Configure the Wireless parameter of your Belkin as you would normaly do.
Using this method, your wired and wireless devices will be able to communicate together since they will be on the same network and your Belkin will act as a bridge between the wired and wireless network.
Apr 20, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
