Question about Haier HVT12ABS Compact Wine Cooler
I HAVE THIS NOW FOR ABOUT 6 MONTHS AND THE TEMP WILL GO BELOW 58F. EVEN ON THE COLDEST SETTING. IS THERE ANYTHING THAT I CAN DO?
  • 111 Answers
If this is a Thermoelectric ,meaning no compressor, then check 2 fuses first,(covered with black heat shrink) next check to see if the inside fan is spinning, if not then replace the fan or check with 6-8 volts DC. Also if there is a green and red led that lights up when you first plug it in your CCB is probably ok...Good luck, safety first ...
Posted on Mar 09, 2009
  • ramon49
    ramon49 Apr 02, 2009
    The company may be the same as Sunbeam (Pederdson) which means they are out of business, chapter 11, got to NET buy for 2.99 and 3.00 shipping, look up panaflo fan and match measurements..
  • 750 Answers
Hello dmeadows,
Happy to assist yo,
You said,
Major appliances all have a 1 year parts and labor warranty. So you can have an authorized service,
do the repairs free, no charge to you.
You can go to the manufactures web site and find a server there or here on our web site.
But just make sure ou ask them if they do warranty work for Haier!
http://www.haieramerica.com/en/support/
Bless You,
Please give me a good rating for solving your question.
Thank You
Posted on Sep 14, 2008
I have a mini fridge from chef mate that does not have a freezer in it. It won't keep temp cold even though it's on highest cold setting. Any answers?
in a fridge the highest or coldest setting is 1 or 0
the bigger the number the warmer the setting
door seal /door not closing properly
have a technician check out the thermostat for correct operation
Dec 10, 2016 | Refrigerators
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
How do I make refridgerator colder....dial is one through 7... is # 1 coldest or #7
1 is the warmest
7 is the coldest
one thing to check is the condenser coil in the bottom behind the grill below the door..remove that grill and clean all the dust from it
when setting the controls nothing happens quickly it takes up to 24 hours to achive the lower temp it was set at
GENE
Aug 27, 2011 | Amana Refrigerators
The bottom freezer is not getting cold even though I set it on the coldest setting. The refrigerator is not getting cold when I set to the coldest temp.
If there is no cooling at all , check to see if compressor is running, if not check for power at compressor if no power see if themostat is open
Jun 22, 2011 | Amana ABB1927DE Bottom Freezer...
Does not blow cold air even when it is on the coldest temp
try to check if your ref. has a evaporator fan if have try to check if operational. check your thermostat if ok by setting it to coldest and compressor continues operation if not thermostat need replacement. try to check yor condenser fan then condenser if dusty. observe unit.
Feb 03, 2011 | True Refrigerators
Food in the fridge part keeps freezing even with setting at highest temp
if its at the highest setting, i.e., the largest number or letter, you have it at the COLDEST setting, and it will freeze in the refrigerated secion. Reset all controls to normal, which is the middle setting. so if your scale range is 1-9, middle setting would be 5, if scale is A-E, middle is C and so on.
After you reset controls, it will take 24 hours for temps to balance themselves out. Your food may take longer to thaw out, so dont go buy whether food is still frozen, instead place a thermometer in the center of the fresh food side. your fridge temp should be in the 35-40°F range. If after 24 hours your fridge section is still below 32, Then you do have a problem, but LG is not a simple unit to diagnose, impossible to do without inspection.
www.FixMyFridge.net
Mar 08, 2010 | LG LRSC26925 Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
What should the supply air temp be on a home a/c system? we cannot get the temp in the house below 80 degrees when the outside temp is above 90. the home is in Alabama. the supply air temp is 66 degrees.
should be more like 58F depending on the the house temp 20 deg. difference from supply air and return. unit is probably dirty and or low on freon. Tom
Jun 18, 2009 | Heating & Cooling
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Haier HVT12ABS Compact Wine Cooler Logo
521 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
