Back to:
Tags:
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Cant figure out how to enlarge a copy on fax...
posted by Lisa_Ann_D on Apr 28, 2008
only settings I see are standard, fine, and half tone and no arrow keys that show on online manual?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 31, 2008
FixYa! (100)
lbcoaster
Rank:Guru Guru
Rating: 92%, 78 votes
To select the resolution Select the desired resolution according to the type of document.
“STANDARD”: For printed or typewritten originals with normal-sized characters.
“FINE”: For originals with small printing.
“SUPER FINE”: For originals with very small printing. This setting only works with other compatible fax machines.
“PHOTO”: For originals containing photographs, shaded drawings, etc.
Using the “FINE”, “SUPER FINE” or “PHOTO” setting will increase transmission time. If the resolution setting is changed during feeding, it will be effective
If you go to:
http://service.us.panasonic.com/OPERMANPDF/KXFHD331.PDF
You will find the online manual for this machine.
Hope this will help you...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cant figure out how to enlarge a copy on fax machine?:
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Fax Machines
garmin oregon 300 won't start. shows boot...
Fax Machines
Cable and Wireless CWF 900 Fax Machine Error light...
Fax Machines
when I want to use my new 3 yeae incredimail, how do I see...
Fax Machines
[269:4] Contains characters that cannot be used.
Panasonic KX-FHD331 Plain Paper Thermal...
prints only 1/4 page. replaced toner,
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
