Modem Driver Problem
I have a dial-up internet service provider. For the past six days I have been having a problem staying online more than five to ten minutes. I called my internet service provider, and the person told me the problem was the connection between my modem driver and their network. He told me to reinstall the modem driver cd. I don't have the modem driver cd to reinstall it. I looked on the internet to see if I could reinstall the modem driver by downloading it from the internet. No luck!
I have Windows 98 and a Intel (R) 536 EP modem.
Thanking you in advance for any help you can give me.
Mia S.
  • Anonymous May 05, 2008
    33.6 faxmodem driver
I need of the drivers FB pctel amr
Posted on Apr 29, 2008
I can't connect internet although i have a driver for it
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you already have the internet
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
May 22, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
I have compaq desktop, but ineed internet driver
download the driver from compaq website make sure you download the correct models driver
Dec 18, 2010 | Compaq Computers & Internet
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
No internet connection
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Click here for step by step instructions
Dec 03, 2009 | Computers & Internet
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
My net disconnects alot
make sure your modem driver is updated, which you can download from the computer's maker's website's support center.
example: hp.com->support&driver
if your modem driver is already updated, then the problem is with your isp (internet service provider). Try calling them about this issue to get an idea of why their bandwidth is having issues.
Jun 25, 2009 | Computers & Internet
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
Compaq Presario.Pentium 4, Vista Windows Home basic. Model SR504OAN Purchased 2007, My son Had Broadband only. Want to use dialup. How do I assertain whether it has an internal modem. On Modems in...
Ok. You want to setup a new Dial up connection.
First, you need to call a service provider and sign up for service with them. Here are a few companies.
  • AT&T Dial - 1-800-524-8500
  • Netzero - 1-888-349-0029 or online
  • People PC - 1-877-947-3327 offer code WEB6
Netzero provides 10 hours free per month with ads.
Personaly, I've had People PC and their customer service is great. On the contrary, I've had Netzero and their wait is at least 2 minutes for a representative. AT&T has also a good customer service.
The service provider you choose is up to you. All of these companies offer speeds of 56Kbps, which is the fastest you can get with dial up. People PC and Netzero offer "internet accelerators".
After choosing, they will send you a CD or you can download their software online.
Click here for PeoplePC.
Click here for Netzero.
At&T does not have their software online.
You already have an internal modem so just install the program and thats it.
Hope this helps.
Aug 05, 2008 | HP Computers & Internet
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
307 people viewed this question
David Payne
David Payne
