Question about Craftsman Computers & Internet
Craftsman 6.5 lawnmower
How do you remove the mulch
ing bag?
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
sean
Posted on Jun 21, 2008
How do I fix the tension spring on a side mulch door on my craftsman lawnmower?
It is removable buy a new one but if it has come loose it will be hard but can be put back with patience and a little sweat.
Sep 12, 2017 | Craftsman Garden
Craftsman riding lawnmower won't bag grass
A very common problem since mowers were made noise compliant, to collect grass you need draught, this is produced by putting a large wing on the ends of the blades and having a high engine speed, unfortunatly large wings and high engine speeds mean high noise, so today the wings are very small and the engine revs low, this leads to low draught and grass blockage, you need to keep the under side of the deck clean and free from old grass clippings, make sure the machine is fitted with collection blades, not mulch blades, i cannot tell you to increase the engine revs, however if for some unknow reason the engine were to start reving higher it would help.
Oct 13, 2012 | Craftsman Garden
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
Lost my manual on my Craftsman LTS 2000 20 HP-wondering if I can mulch leaves with my lawnmower and how?
They make a mulch cover for the discharge chute and a good set of mulcher blades. You need the 9 digit model number from the label under the seat and you can get them from sears
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lawnmower dosent bag grass correctly(leaves clumps of grass behind) also doesnt seem to have the power it once did.Not sure whats up.
there is a little do dad that fits in the hole that the grass is suppose to come out of called the rear mulching baffle that blocks the hole to the bag... remove it and shuld be ok
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Removal of blade from black & decker lawn mower gx530
i used impact gun with 3<4 socket and run the impact in reverse
May 26, 2008 | Black & Decker 19" Electric Lawnhog...
Computers & Internet Logo
213 people viewed this question
Top Craftsman Computers & Internet Experts
David Payne
David Payne
Are you a Craftsman Computer and Internet Expert? Answer questions, earn points and help others
