Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Help I have a belkin F5D7050B model and utorrent says i have no incoming connections please help
  • Mark Gil
    Mark Gil May 11, 2010
    How many computer do you have?
    Is the Utorrent working directly to your modem?
  • Belkin Master
  • 6,487 Answers
There's a possibility that torrent is being block by the router where your computer is connected to , if internet is working on this computer and torrent is the only one not working you need to open the port for torrent on your router....
Posted on Oct 25, 2008
Got utorrent and down loaded ipv6 ,download speed very very slow disabled ipv6 and uninstalled utorrent and re installed utorrent and tryed other torrent downloaders all say ipv6 installed ,done the...
With utorrent you have to go into the options menu at the top right, then click preferences....once in there click on 'Connection'. The information window to the right has some changes you need to make....the first one where it says 'Port used for incoming connections'...change that to 64450 (you can use any random number over a certain range I generally choose one between 62000-64999). Now right below that, make sure the check box 'Add Windows Firewall exception' is checked. Now click 'Ok' and close the program then go and try to download your torrent.
(If you are using a 3rd party firewall program you will need to go in and enter an exception for utorrent manually)
Feb 23, 2011 | Computers & Internet
Connection problems
1.Visit: www.belkin.com/support
2. On the top right corner, there will be a search by keyword, a small rectangular blue box
3. In that, type in: F5D7050 and press enter
4. It will give you search results, select the result that says "Drivers".
5. Select the appropriate version for your model. Belkin has 5 versions for the same model. Check for FCC no. on your device. There would be a table on that web page.
6. Verify, download and install
Feb 18, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
How to port forward for microtorrent on belkin n1 vision
Here is a good walk-through how to set up utorrent on your router.
Enjoy!
PS: Make sure that utorrent is not blocked by your Windows firewall!
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 12, 2009 | Belkin N1 Vision Router
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Zoom 4410 B for macintosh
i took it back and got a Belkin F5D7050B and it works now!
Jan 18, 2009 | Zoom Wireless-G 4410 (44100000) 802.11g/b
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
Problem downloading a torrent file
which torrent software is it?
try with utorrent its great and it works good
Jun 14, 2008 | Microsoft Windows Vista Ultimate Edition
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
109 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
