Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Samsung HL-R4266W makes a roaring noise like a motor running.
  • 1 more comment
  • rspsr Apr 28, 2008
    Can a person replace it without a service call? How would you do that?
  • Anonymous Jan 22, 2009
    How much does it cost to repair this issue?
  • Scott
    Scott May 11, 2010
    Low hum or loud roaring? How loud is it? If a DLP tv, it could be the motorized color wheel going bad.
    Scholar:
  • 186 Answers
Yes - I believe a person can with moderate technical skill. I think it's called a light engine. Partstore.com is a decent online resource for parts but it looks a little pricey there. You might dig around and see if you can find one cheaper. It also might not hurt to bug Samsung on the phone about this problem to see if they issued any program/ recall or extended service regarding the issue. I don't believe it will damage anything else, and as time wears on, the color wheel will get slower with colors less acurate on the screen or the bad motor will burn out completely leaving you probably stuck on one color similar to a black and white tv. Good luck and hope you get it fix.
Posted on Jun 07, 2008
  • Scott
    Scott Jun 07, 2008
    Sorry - forgot to check spelling in  previous post - Scotty
I have a samsung model #HL-R4266W tv, It is making a humming sound, and has no color other than it being in black and white the picture looks fine, what could be the problem?
This tv design have a colors wheel in it,have humming sound or loud motor noises.The colors flashes Black&White or lost all colors.The colors wheel is dying and the causes.The colors wheel replacement are not a do it ur self project.Hire a tv Tech. to do it right the first time.Colors wheel sit way back close to the Light Projection Engine itself.
Dec 30, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung hl-r4266w
it is more than likely the bulb you can pull it and see if it is broke or looks bad if so replace first than go from ther
Jan 24, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
We lost the pcture on our Samsung HL-R4266W and we got a blinking "Lamp" in the center of the screen while there was a deep humming noise. I called Fry's Electronics where I had purchased the TV in Dec....
I learned that the problem was a broken color wheel instead of a bad lamp. It appears that the color wheel gets very hot and brittle because of the proximity to the lamp. Eventually, parts of one or more of the glass wheel-blades break off and make noise if they are still next to the wheel.
Jan 07, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
My Samsung DLP TV HL-R4266W is making a noise when I Turn it off. It sounds like the fan is rubbing on something. I took the back off and all 3 fans look fine. Could the noise be the Color Wheel and is...
Yes, the Color Wheel would be the only thing left. I am not sure about this exact model but the Color Wheel in other Samsung models are replaceable.
Hope this helps,
Skyassoc
Jul 06, 2009 | Samsung HL-R4264W 42" DLP HDTV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung HL-R4266W 42 shutoff
have the power supply checked it may be faulty
Oct 19, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung hlr4266wx dlp tv shuts off
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
Jan 14, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
172 people viewed this question
Henry  Thomas
Henry Thomas
