I have just bought a new pc and thought i could use my old hansol 720e crt monitor until i discovered there i no power plug on the back of the tower to plug the monitor power connector into. craig
  • 655 Answers
No problem,
  • just use another power card which you are using for your computer.
  • It will work with your Old CRT.
  • You may connect it directly to the power socket.
Thanks
Iqbal
Posted on Apr 28, 2008
When i turn on monitor,it didint have any picture but it was on
Make sure that it is connected correctly, if its connected correctly check to see if your motherboard is working by taking off the side of the tower and seeing a green light.. if that is working then the next option is to get a different monitor or borrow one and plug it in and see if it was the monitor if so then buy a new one..
Oct 27, 2012 | Hansol 730 ED 17" CRT Monitor
In 2004 I bought a monitor Hansol 930 D model, (model no.D19BL, s/n A23490411020263) Since 2011, horizontal image began to narrow, now horizontal image H-size is 210 mm. vertical image size is ...
The horizontal deflection coil is shorted. There is no way to fix that, the entire tube would have to be replaced and that would cost as much as a new monitor.
Just buy a second-hand LCD monitor from here
http://www.diabloscomputer.ro/monitoare-second-hand-fujitsu-siemens-p19-2
Asta l-am luat eu si are o imagine excelenta.
Jul 01, 2011 | Hansol Europe 930D 19" CRT Monitor
Hi, My Hansol H550 used to come on when my PC tower was booting up, but now I have to press the green on/off button. BUt unfortunately, after pressing the on off button the screen only comes on for a split...
Sounds like there is no input to the monitor. Check the video cable(the one with the screws). Even if it looks plugged in, unplug it and replug it at both ends.
Feb 27, 2011 | Hansol H550 15" LCD Monitor
Monitor wattage
Spec:
http://www.hansol.nl/eng/730e.html
Since the company will nor even list the power consumption, You can make an estimate by reading the voltage and the current consumtion on the label, multiply voltage by current will give you wattage, but since the monitor is not linear load but reactive load, the power factor will not be 1 but usually about 0.6.
IE, 100V X 1AMP = 100VA. 100VA X PF OF 0.6 = 60WATTS.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Hansol 730E 17" CRT Monitor
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
How to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
May 03, 2009 | Televison & Video
Resolution hansol 730E
interesting, have you tried perhaps a monitor screen?
Feb 11, 2008 | Hansol 730E 17" CRT Monitor
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
