Question about Gateway FPD2275W LCD Monitor
LCD monitor image blinking
Thanks for your earlier post about the light/controller.
On my Envision LCD, on any computer, it displays the image about .25 seconds while a faint sound of "energizing/de-energizing" is heard, then it goes blank for about 4 seconds. Do you know if LCD's tend to have bad capacitor issues like CRT's? 'Or perhaps another common issue that would cause this phenomena?
Thanks for any help you can offer,
Steve
  • Anonymous Apr 30, 2008
    Acer logo flashes (1 second) then the screen then back to the logo and so on. I tried rebooting, unplugging - took the computer to the shop - added RAM.
  • 111 Answers
There are two coils in the circuit board that normally causes this problem due to dry solder. try to desoder clean and resolder these coils.
Hope this helps.
If it does, please vote. Thanks!
Posted on Apr 30, 2008
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
No display. power light blinks green. no menu or other buttons work. Using Windows xp pro. ideas?
Look for bad caps as shown (the 19" uses same chassis as the 17" or close to i,t depends on version)
http://s807.photobucket.com/albums/yy352/budm/Envision%20EN7410E/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 08, 2010 | Envision EN9410 19" Flat Panel LCD Monitor
LCD EN 7500 THIS HAVE SONG AND NOT IMAGE
Need to check the caps in power supply, fuse and transistor/IC/transformers in the inverter circuits, it can also be bad lamps assemblies.
See example of failed 7410 due to bad caps. Post back for furhter help.
Service manual: http://elektrotanya.com/?q=showresult&megnev=Envision%20&megnev2=%20EN%207500%20&kategoria=&kat2=all
Apr 27, 2010 | MPC Computers Envision EN 7500 17" Flat...
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
My Envision H22w Monitor has a green light that is blinking but is not working. IT was working earlier but just went off.
mine just did this tonight. envision has a 3 year warranty and mine was within that so i am rma'ing it.
Sep 29, 2009 | Envision H22W 22" Monitor
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
