Question about Mamiya ZD Digital Camera
Mamyia ZD flashing busy
I have just encountered the same problem - did you ever find a solution? Disconnecting the battery stops the flashing, but it starts when I turn it on again.
It happened to me last year in July 2008. All the images were wiped off the card.
I was told by Robert White cameras in Poole, Dorset, England from where I bought the camera that it was a card problem. With the card connected to your Mac by a reader, go to Apps, Utilities folder, Disc Utility. Select the card from the menu on the left. Select Erase and then choose how many times you want to erase. This will take a few minutes but will clean the card. Never use a card from another camera. Just use cards for use in the ZD only.
I have not had the problem since.
Cheers, Tony
Posted on Jun 03, 2009
I took the battery out. Put it back in and it was fine.
Haven't had a problem since.
I guess the trick is not to let the battery die while you're shooting or while the camera is connected to a computer. Obviously.
Posted on Jan 16, 2009
I have a nissan hardbody with zd 30 engine ,which we have replaced the injector pump from another running car timing perfect we locked the gear vehecle cant start diagnosis is showing pick up sensor and 1...
I try not to guess when I'm on here trying to help people, but here goes... You might want to try disconnecting the negative cable from the battery for a couple of minutes, then reconnect it. This will cause the on-board computer to re-boot. It may recognize the new parts then. Again, I'm sorry, but I'm just taking an educated guess. Good luck! Hope it works. Bill
Aug 01, 2014 | Cars & Trucks
Lights flash when battery cables are connected
Disconnecting and reconnecting the battery cables sets up the security alarm system which is part of the flashing lights. To stop the flashing, insert your key into the drivers side door lock and and turn to the unlock position. This will also stop any unwanted security alarms.
Nov 30, 2012 | 1995 Jeep Grand Cherokee
Hi all experts how can i get the position of accelerator Control censor?
depends on the year of the vehicle if a later one then its dealer only with the correct software which is connected to the internet with digital signature and encrypted software to stop people like your truely from doing the job
Sep 22, 2012 | Cars & Trucks
Service engine light flashes then solid then flashes.car runs rough when stopped.2005 v 6 mustang
the flashing and stopping is a code if you look in manual it will show you what code it is count the flashs between the stop and look it up or try disconnecting battery for 5 minutes the reconnect this should reset cpu then if it does this again have it diagnosed on computer to see what fault it is
Jul 08, 2011 | 2005 Ford Mustang
My 2005 Dodge Dakota's alarm won't disengage. I have tried disconnecting the battery and everytime I connect it it goes off again. The truck will not turn over. The battery is not dead and the lights flash...
I just encountered this exact problem tonight. The engine will start, but the alarm continues until I disconnect the battery. Nothing else works. Have you found any solutions, zenythe?
Jan 10, 2011 | 2005 Dodge Dakota
91 chevy 1500 ac light flashing
try disconnecting the negative battery cable for ten minutes to reset the computer.
good luck
Jun 24, 2009 | 1991 Chevrolet K1500
My 2001 chevy malibu ls v6cranks,starts up but right after,right after dies like somethings shutting it down. radio was locked from me disconnecting my battery without disconnecting the anti theft system....
Is the Security light flashing??? If so, the security system (passlock II) is ******** off the fuel because the car thinks it is being stolen. If the security light is flashing, leave the key in the "on" position for about 10 minutes and it will stop flashing. Then turn the car off and try to start like you normally would.
May 06, 2009 | 2001 Chevrolet Malibu
Hazard lights flashing
I have a 97 subaru outback and encountered the same problem. It is a security device on all newer subaru's. After changing or charging the battery, leave the negetive battery cable disconnected. Turn the key to the "on" position, then reconnect the negative terminal. This will stop the flashing.
Jul 06, 2008 | 1998 Subaru Forester
Electric light flashing
This indicates that your battery isn't functioning properly or is going bad. You need to replace the battery. Bateries are batteries, some are better than others and some wear out faster than others, even though they may be the same brand, eventually all batteries need replacing.
Jun 20, 2008 | HP Business Notebook 530
Mamiya ZD Digital Camera Logo
531 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
