Question about Microsoft Windows XP Home Edition
Connection Wizard problem
I am unable to connect to internet. I checked my registry and did all the steps advised on microsoft site. I deleted telephony registry but still connect using dial up option is dimmed. i did system restore also please suggest me wat to do
    Genius:
  • 2,785 Answers
Recreate your internet connection and do a system scan for viruses
Posted on Apr 29, 2008
Internet connection is no longer working
You can follow the step by step instructions given from Windows.microsoft.com to solve the internet problem.
If you need to check your internet speed visit Scanmyspeed.com .
Troubleshoot Internet connection problems
ScanmySpeed Check my Internet Speed
Jan 09, 2014 | Computers & Internet
Unable to read cdrom burn in XP
Either run this tool on ur computer http://support.microsoft.com/gp/cd_dvd_drive_problems
or if u want to learn how to do it urself.. then heres the answer.. BE VERY VERY SURE OF WHICH SUBKEY U DELETE OFF THE FOLLOWING OPTIONS.. HOWEVER IF U DO IT PROPERLY.. UR A CHAMP..
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
need more help .. let me know.. regards, Guru :-P
Apr 30, 2010 | Microsoft Windows Vista Ultimate Edition
Winsock
This infomration is regarding Windows XP SP2:
For more information about how to back up the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows XP and Windows Vista
  3. In Registry Editor, locate the following keys, right-click each key, and then click Delete: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock2
  4. When you are prompted to confirm the deletion, click Yes.
Note Restart the computer after you delete the Winsock keys. Doing so causes the Windows XP operating system to create new shell entries for those two keys. If you do not restart the computer after you delete the Winsock keys, the next step does not work correctly.
Step 2: Install TCP/IP loadTOCNode(4, 'resolution');
  1. Right-click the network connection, and then click Properties.
  2. Click Install.
  3. Click Protocol, and then click Add.
  4. Click Have Disk.
  5. Type C:\Windows\inf, and then click OK.
  6. On the list of available protocols, click Internet Protocol (TCP/IP), and then click OK.
    If Internet Protocol (TCP/IP) does not appear, follow these steps:
    1. Click Start, and then click Search.
    2. In the Search Companion pane, click More advanced options.
    3. Click to select the following three check boxes:
      • Search system folders
      • Search hidden files and folders
      • Search subfolders
    4. In the All or part of the file name box, type nettcpip.inf, and then click Search.
    5. In the results pane, right-click Nettcpip.inf, and then click Install.
  7. Restart the computer
Apr 14, 2010 | Microsoft Windows XP Home Edition
My Optiarc cd-rw crx880 doesnt work, tried to delete those two regisrty but nothing change.. pls help..
Hi, Before deleting the registry key (most probably the upper and lower filter) try to locate your cd drive in the Device Manager. If it is present, delete it and then delete the upper and lower filter registry key.
If you are unable to find the cd drive in the Device Manager, then there is an issue with either connection to the cd drive or else cd drive is itself faulty.
Feb 14, 2010 | Microsoft Windows Vista Ultimate Edition
Windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
Facebook websites not opening
is it facebook site alone which unable to open?
Check the internet connection under file menu of internet explorer.
Aug 14, 2009 | Microsoft Windows XP Professional SP2 Full...
Unable to access microsoft.com; same connection on laptop works fine
what web browser are you using with the pc? microsoft blocks users that are using anything other than internet explorer, cannot access with firefox or opera unless you change your user agent.
Apr 30, 2009 | Microsoft Windows XP Professional
Error [678]
Hi, Step 1: Make sure the network cable is connectedMake sure that the network cable is connected to the computer and to the modem. If your computer connects to a hub or to a router, make sure the cable that connects the hub or the router to the modem is connected. Step 2: Make sure that the network adapter is enabled
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click the Local Area Connection icon. Click Enable if the option is available.
Step 3: Reset the modem
  1. Disconnect the cable that goes from the computer to the modem.
  2. Turn off the modem. If the modem does not have a power switch, disconnect the power supply from the modem.
  3. Wait two minutes.
  4. Turn on the modem, and then connect the cable that goes from the computer to the modem.
Step 4: Uninstall and then reinstall the modem and the drivers by using Device Manager
Before you follow these steps, you may have to download the latest driver for your network adapter from the hardware manufacturer.
  1. Click Start, click Run, type sysdm.cpl, and then click OK.
  2. Click the Hardware tab, click Device Manager, and then locate Network Adapters.
  3. Expand Network Adapters, and then right-click the icon for your network adapter.
  4. Click Uninstall, and then click OK. In the dialog box that prompts you to remove the files that are associated with this device, click Yes.
  5. Restart the computer. Or, click Action, and then click Scan for hardware changes.
  6. If Windows finds the device but does not recognize it, you must install the latest driver for your network adapter.
If you have a Realtek 8139 network adapter, updating the driver seems to resolve this issue. For more information, visit the following Realtek Web site: http://www.realtek.com.tw/downloads/Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Step 5: Create a new DSL or cable connection
  2. Click Create a new connection under Network Tasks. Click Next when the wizard starts.
  3. Click Connect to the Internet, and then click Next.
  4. Click Set up my connection manually, and then click Next.
  5. Select Connect using a broadband connection that requires a user name and password, and then click Next.
  6. Follow the remaining steps. Use the connection information from your Internet service provider (ISP) to complete the wizard.
Note You may have to use software that is supplied by your ISP to create the new connection.
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Csrcs.exe spyware
This was posted via symantec: link:
http://www.symantec.com/security_response/writeup.jsp?docid=2003-053013-5943-99&tabid=3
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Click OK.
  5. In the Registry Editor, navigate to the following subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    RunOnce
    RunServices
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\
    RunServices
    RunOnce
    HKEY_CURRENT_USER\Software\Microsoft\OLE
  6. In the right pane, delete any values that refer to the file names that were detected.
  7. Navigate to the subkeys:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wscsvc
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\TlntSvr
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RemoteRegistry
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Messenger
  8. In the right pane, reset the original value, if known:
    "Start" = "4"
  9. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
  10. In the right pane, reset the original value, if known:
    "restrictanonymous" = "1"
  11. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\
    parameters
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanworkstation\
    parameters
  12. In the right pane, reset the original values, if known:
    "AutoShareWks" = "0"
    "AutoShareServer" = "0"
  13. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
  14. In the right pane, reset the original value, if known:
    "DoNotAllowXPSP2" = "1"
  15. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\OLE
  16. In the right pane, reset the original value, if known:
    "EnableDCOM" = "N"
  17. Navigate to and delete the following subkeys, if present:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\BoolTern
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_BOOLTERN
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\rdriv
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_RDRIV
  18. Exit the Registry Editor.
5. To delete the zero-byte files from the Startup folder
Follow the instructions for your version of Windows:
Note: There may be legitimate files on your system that start with "tftp." Delete only the zero-byte files from the Startup folder.
To delete zero-byte files in Windows 95/98/Me/NT/2000
  1. On the Windows taskbar, click Start > Find (or b) > Files or Folders.
  2. Make sure that "Look in" is set to (C:) and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, type, or copy and paste, the following file name:
    tftp*.*
  4. Click Find Now or Search Now.
  5. Delete the files that are zero bytes in size and contained within any folder whose name ends with "Startup."
To delete zero-byte files in Windows XP
  1. On the Windows taskbar, click Start > Search.
  2. Click All files and folders.
  3. In the "All or part of the file name" box, type, or copy and paste, the following file name:
    tftp*.*
  4. Make sure that "Look in" is set to "Local Hard Drives" or to (C:).
  5. Click More advanced options.
  6. Check Search system folders.
  7. Check Search subfolders.
  8. Click Search.
  9. Delete the files that are zero-bytes in size and contained within any folder whose name ends with "Startup."
6. To reenable the SharedAccess service (Windows 2000/XP only)
The SharedAccess service is responsible for maintaining Internet Connection Sharing and the Windows Firewall/Internet Connection Firewall applications in Windows. (The presence and names of these applications vary depending on the operating system and service pack you are using.) To protect your computer and maintain network functionality, re-enable this service if you are using any of these programs.
Windows XP Service Pack 2
If you are running Windows XP with Service Pack 2 and are using the Windows Firewall, the operating system will alert you when the SharedAccess service is stopped, by displaying an alert balloon saying that your Firewall status is unknown. Perform the following steps to ensure that the Windows Firewall is re-enabled:
  1. Click Start > Control Panel.
  2. Double-click the Security Center.
  3. Ensure that the Firewall security essential is marked ON.
    Note: If the Firewall security essential is marked on, your Windows Firewall is on and you do not need to continue with these steps.
    If the Firewall security essential is not marked on, click the "Recommendations" button.
  4. Under "Recommendations," click Enable Now. A window appears telling you that the Windows Firewall was successfully turned on.
  5. Click Close, and then click OK.
  6. Close the Security Center.
Windows 2000 or Windows XP Service Pack 1 or earlier
Complete the following steps to re-enable the SharedAccess service:
  2. Type services.msc
    Then click OK.
  3. Do one of the following:
    • Windows 2000: Under the Name column, locate the "Internet Connection Sharing (ICS)" service and double-click it.
    • Windows XP: Under the Named column, locate the "Internet Connection Firewall (ICF) / Internet Connection Sharing (ICS)" service and double-click it.
  4. Under "Startup Type:", select "Automatic" from the drop-down menu.
  5. Under "Service Status:", click the Start button.
  6. Once the service has completed starting, click OK.
  7. Close the Services window.
Jan 13, 2009 | Microsoft Windows XP Professional
Unable to download anything from internet
check your Internet ambition, it is obvious that your Internet Connection is breaking Jethro. check with the connection or with the Server saved luck.
Jun 26, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Home Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
