Question about GE Energy Star WCVH6260F Front Load Washer
Torn gasket on a front load ge washer
How hard is it to replace the door gasket on ge washers and where can i purchase them
  • jennydanko Nov 11, 2008
    Please let me know how you fixed it once you got the part- can you post instructions from John in Erie? Thanks
  • bbm300m Apr 20, 2009
    My door gasket has torn for the second time. I am not going to pay the appliance company to install again. Where can I find John in Erie directions to install? This washer has been the biggest disappointment. I would love to get rid of it and start over!!!!
Not too hard or technical. I followed John in Erie's instructions:
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
I bought my part at Appliance Zone. From what I paid and how long it took to get to me, I should have just bought it locally for a little more and had it delivered a lot sooner. Replacement took an hour and a half.
Posted on Dec 21, 2008
I had the same problem with this washer, and after reading the solution/instructions posted here on FixYa decided to purchase the gasket and try to do it myself. The first time this happened, after about 10 months, it was under warranty and was fixed by GE. This time it wasn't under warranty, so I decided to research the process online, which led me to FixYa. The gasket is called the door boot seal, and is available at appliance parts stores, online applicance part stores, and at GE's parts site. The part number is WH08X10022 and can be found for somewhere between 90-110, plus shipping. I picked it up at a local store for 125 bucks.
With the help of a friend, I followed the instructions given by John in Erie, and it worked extremely well. The entire process took less than 2 hours, and saved me hundreds of dollars in service visit costs. Thanks to John and everyone who is trying to help those of us who have this GE model with its poor design. All you need to do it is a phillips screwdriver and some patience.
The washer is working flawlessly now. Thanks again for the help. Best of luck to all who want to replace the boot seal themselves... you can definitely do it.
AW
Posted on Jun 01, 2008
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
We discovered that our front door inner gasket is torn. Therefore, it's leaking during every load out of the door. I will be ordering the part but concerned that I won't be able to replace it. Do you...
If you've not done this before, expect to spend a lot of time. I've replaced these without disassembling the washer's front, but it's an arm-twisting experience to put the inner part of the gasket on, and to attach and tighten the clamp holding it. Haven't tried removing the front panel, if you can, do it - the job becomes much easier.
PS Check shocks and if the washer is leveled enough, door gaskets tear from excessive loads and excessive vibration.
Mar 29, 2010 | GE WBVH6240F Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Our gasket tore. How do you replace the gasket?
Its actually pretty easy.
1, Remove the top of the washer
2. Remove the screws behind the front panel with the knobs and buttons. set the whole assembly on top out of the way
3. remove the door of the hinge. there are 4 screws
4. remove the concrete weight
5. remove the back band folding gasket. It has a bolt.
6. remove the front band, its just under spring tension
6. replace gasket and install back band first.
7. work your way backwards from here.
Good luck
Scott
Jun 14, 2009 | GE WBVH6240F Front Load Washer
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
Replacing the door gasket on ge front load washer
very hard to replace if you hav not done it befor to get it installed correctly
Apr 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
2,878 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
