Question about Sony Playstation 3 (PS3) Console
P S 3 will not play MLB 08 just when game starts it freezes up sound keeps playing screen is blank same with downloadable demo games from playstation store
  • budsco Apr 29, 2008
    tiger woods PGA 07 & 08 work good - few other games are fine- brought mlb 08 from amazon.com Have read about router problems connected to dsl modem directly did not help. 70 year old retired man knows little about computers
    President:
  • 2,712 Answers
If you are having issues with the screen freezing after the press start screen, this has to do with your automatic I.P. address configuration on your PS3. On your computer go to the command prompt (to get to command prompt, click START > Run. In the box that opens up, type cmd. This will give you a black window with something written on the top ), Here is a pic:
Type in ipconfig .It will show you the default gateway for your router/DSL. Type that into your web browser to access your router configuration. From there you can find the I.P. for the PS3 and default DNS servers. On your PS3, go to the network settings and manually enter in the I.P address for your PS3, the default gateway, and the default DNS servers. After that, it should load up fine for you.
Note: You will need the password for your router. Some have defaulted "admin" as the password, or whatever you used when you set up your router for your network.
If that doesn't work, HERE is another solution.
Hope that works!
Cheers!
IrishDruid
Posted on Apr 29, 2008
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Also try what TheMachine said below..try the game without the internet connection. If it works, you do not need to follow the steps above. But then, that would give you only 50% value for what you paid for the game..
    If it does not work even without the connection, then the disk is defective and try to get it replaced.
    Try this as well:
    1. Disable
      auto sign in to the PSN.
    2. Start
      the game.
    3. Decline
      the first attempt to log on at the PRESS START screen.
    4. Log in
      at the Sports Connect screen.
    Here is a quote from a different forum:
    “I use a Belkin wireless router, and I was having the
    same problem (freezing after the "press start" screen). I was
    able to get around this by manually changing the network settings in the PS3
    menu... I'm not sure why this worked, but it worked - instead of having
    the PS3 automatically check for the IP address, I manually typed in what I
    thought it should be. Now, I do not know much about network
    connections.... but, if my desktop PC's IP address ended in xxx.2.2, and my
    laptop ends in xxx.2.3, I typed xxx.2.4 for the PS3. I also manually
    copied the same DNS server addresses that are on my desktop PC into the
    appropriate fields during the manual setup in the PS3 network setup.
    Once I finished typing in all the addresses, I was able
    to go online and play games, download rosters, etc. “
    Master:
  • 788 Answers
Are you able to play the game without an Internet connection at all? This would eliminate or prove that your router or Internet connection is the culprit. Otherwise could be a defective disc, that will happen sometimes. Bring it back to the store and have them try it out, if it does the same thing they should happily replace the game.
  • Dean Joly
    Dean Joly Apr 29, 2008
    Sorry, contact Amazon or EA, they will replace your disc if it's defective.
    You could also try it on a friend's PS3 if you know someone to see if it reproduces itself.
    Genius:
  • 3,422 Answers
try to keep it in an open breathable area.. you are most probably likely to freeze if your ps3 is too hot
but there are some games that has some issues and freeze..
Goodluck..
  • 655 Answers
If you are using belkin router? thats your problem right there. it freezes at the start screen because of some issue with belkin router.
Thanks
Iqbal
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Apr 19, 2012 | Sony Playstation 3 (PS3) Console
3.0 Killed my PS3
Sounds like the laser diode burned out. If your under warranty send it in. If not you could buy a replacment and install it yourself.
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
Mlb 09 gets stuck at first loading screen.
I cannot solve this my friend,
BUT I have the exact problem with call of duty world at war
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
My XBox 360 freezes
Here are things to try.
1. Try another game and check if it only happens on this game ( MLB 2k9 )
2. Select memory -> Select Y button for device options then press the following sequence on your controller
X,X Left Bumper, Right Bumper, X,X
You will see a message that goes like this " This will perform maintenance on your xbox 360 storage device, would you like to continue? Select Yes
3. Delete your save game. or try to start a new game..
Because this is an indication that the certain point that you are trying to load is already corrupted and its your saved game.
Apr 04, 2009 | Microsoft Xbox 360 Elite Console
Career mode freezing up after playing a game
You may need to clean your PS2 mine did the same thing tilli cleaned it. the littlest bit of dust messes with it. hope this help you have a good day.
Mar 26, 2009 | Sony MLB '08: The Show
PS3 wont load or play games, Just a blank screen.....
Try playing a Demo game, if you dont have any download it from playstation network. The point is just to force the sytem to play games and if you notice, movies and games are listed under a different folder in the icon's list, so playing a demo game will force the system to play the game and you should be able to play your games fine after that,. Thing is that a game's info might've got stuck in freeze mode when the system was shut off unproperly while a game disk was still inside, that's all. Good luck, dont wanna see any PS3 comrades suffering the unspeakable horridness of not been able to play games. Be strong my friend.
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
PSP MLB 08
cleen the umd laser with a q-tip and windex. dampen the q-tip andwipe across umd laser. dry with other side of q-tip. take out game wen turning psp on
Apr 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
