Question about Jura Capresso C1500 Espresso & Coffee Maker
Espresso C15---weak coffee
My C1500 has started to produce very, very weak coffee (aka, dishwater). I've run through the cleaning procedure (with the prescribed tablets), cleaned the disk above the tray, cleaned the bean container, etc.
  • Jura Capresso Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
Clean unit
After making approximately 200 coffees, the internal brewing chamber and the
brewing unit must be cleaned (of coffee oils, etc.). The display will show
CLEAN UNIT alternating with the regular message. This indicates that it is time
to run the tablet cleaning cycle
Feb 20, 2012 | Jura Capresso C1500 Espresso & Coffee...
Coffee is cold and not brewed properly. Unit has been cleaned,de-calcified, rinsed, but still the coffe is cold. temperature is set to high, and the machine can produce steam. Anyone help?
Apr 02, 2009 | Gaggia Titanium Espresso Machine
Water does not come out the frother/hot water spout .
check your solenoid valve and security valve of boiler of the machine. make sure they are clean and work good, than you will have perfect espresso again.
if pump runs without your comand check up the swich of brewing coffee.
Mar 31, 2009 | Jura Capresso C1500 Espresso & Coffee...
Capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee weak
IT MIGHT NEED DESCALING RUN SOME WATER AND WHITE VINEGAR THEN RUN CLEAN WATER A COUPLE OF TIMES AND MAKE COFFEE SEE IF ANY BETTER PS WHITE & ONE SUGAR FOR ME THANKS HOPE THIS IS HELPFUL GLENN.............
Nov 15, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Jul 16, 2008 | Gaggia Titanium Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Jura Capresso C1500 Espresso & Coffee Maker Logo
516 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
