Philips tv model 28pw6315/05. power ok? (power light on standby) but no picture, no response from remote control or tv power on button, tv emitting a cocstant hum is this an error signal & if so whats happened?
Think it may be ic7064 (ASSB112HL).this seems to be a quite common power up/lock up problem.
Posted on Oct 21, 2008
  • techtony Oct 21, 2008
    Try & download a service manual if you can. It may have to be set up if you replace this painter chip.To get into service mode enter 062596 then status button(might be i+) on remote.Make sure you note the correct option codes.They should be on a sticker on tube eg 126 69 14 24 000. use remote to change these. The chip is a SAAB112HL NOT ASS112HL(TYPO ERROR SOZ).
    Good luck
    techtony
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
The remote works but the tv does not pick up the signal, what can i do?
Check whether the standby/power LED at the front of the TV light up, when power is switched ON. If not, the 5V standby supply is not there, and the remote sensor also won't get power, and won't work. If this LED lights up, standby/power voltage is there, and the infrared sensor inside the TV is faulty, provided the remote control emits infrared rays for each press of its button. If it is a universal remote control, if you have taken out its battery from its battery compartment, the remote had resetted by itself, and you should set it with the setup code to your TV once again.
If you wish to get more details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 11, 2014 | Televison & Video
IR sensor and side buttons don't work
Check the remote control first for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside the battery compartment, for any dust or rust accumulated. If you wish to know more about how to check and clean a remote control, check this link. If remote control is found OK, check and replace the infrared sensor inside the TV. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 26, 2013 | Philips 27PT543S 27" TV
Wont go on standby
Possible that the processor section needs to be checked. When the remote is clicked to standby and if there is no response even if the remote is working perfectly with other modes then the power - off button and IR trigger from the remote must be checked to work. Use a mobile camera to see if the remote is emitting IR with the power off button pressed.If so the processor section and the standby out must be traced.
Jan 20, 2012 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Philips 28pt4523 tv - power on but no response to
check capacitors on power board if they are ok suspect is the tuner board
Mar 26, 2010 | Televison & Video
I have a 27" magnavox tv and it's on standby and i don't have the remote to turn it on is there any way i can get it to turn back on without the remote or can i get a a universal remote or anything please...
if there is any buttons on tv some tvs have cover over then on frount or side of any press ch.up or ch.down
is no buttons can be seen you can find remote on chylse hyde and son web site (CHS) tou will need make and model of tv
hope this helps
MERRY CHRISTMAS
Dec 14, 2009 | Philips Magnavox 27MS343S 27" TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
