Question about Siemens Se5954 (120-5954-003) Firewall
Firewall How do I turn off the modems firewall?
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    Are you refering to the Modem that your service provider provided you for your internet connection?
    Problem Solver:
  • 23 Answers
If you are referring to your connections built in firewall then goto network connections and right click on the item and select properties. If there is a built in firewall to the network device you will see it in the list. Uncheck the box to disable it.
Posted on May 23, 2008
Youtube not working on this moden DCM315 with comcast.
There is no way in whihc YouTube will be stopped by modem! modem is just "translating" signal from telephone/satellite to computer. Modem do not control contents of the communication.
You need to find what piece of software on your computer is preventing you from accessing YouTube, try to disable first FireWall and then check if you have YouTube.
If you have YouTube after disabling FireWall, you need to switch on your FireWall and create permission on it to allow YouTube to pass through.
I cannot provide more detailed information as you did not provide me with what operating system you use and what firewall you have installed.
Hope this help solve your problem and you will be again enjoying your YouTube.
Aug 08, 2010 | RCA Cable Modem DCM315R (11603540)
I want turn off firewall from my modem
to turn off windows firewall click on start and then control panel then open windows fire wall or just search there windows firewall and then click on of firewall and save changes and apply
if this information helped you then vote for it and thanks for using fixya
Apr 19, 2010 | Arris Touchstone 450a (CM450) Modem
I cannot install the latest version of yahoo messenger
Your Windows firewall may be interfering with the connection. You can unplug from the internet, then turn off your firewall, (security center), then install, then turn the firewall back on and reconnect your internet cable.
Or, follow the instructions from Yahoo here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | Microsoft Windows XP Professional Upgrade...
Disabling the firewall?
You have to know the required ports for music downloading in order for you to configure on your router.
Mar 01, 2009 | Westell Wirespeed ProLine 6100 Router...
Connecting the GT704WG DSL modem/router
disable your firewall temporarily to see if the firewall is what causing the problem, are you using windows firewall.??
Feb 17, 2009 | Actiontec GT704WG Wireless Router...
Need to network SG300 Firewall and Qwest (Motorola) 3347-02 Modem
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
Three Firewalls
You can't 'uninstall' the Windows Firewall, just deactivate it. Another option is to turn off the modem firewall (the strongest of the three, now two) and to activate the Windows one (the weakest but most annoying one). Now you stated that you can't use Internet Explorer but everything else was ok, skip IE, use Firefox or Opera.
Aug 30, 2008 | Computers & Internet
Westell 6100, to smart for job!
you have to activate DHCP in order to make the westell a modem "dummy" (it will just act as a bridge to the internet from your Linksys.
on the modem, go to a setting that is similar to "Public Routed Subinterface". dont choose anything that says "proxy" or "NAT".
find out the Linksys's IP adress by looking at the devices or computers list on the Modem's home page.
Now, put that IP adress on the setting "Public Routed Subinterface" (or similar). If it has a "Subnet Mask" option, type in "255.255.255.0". Also, If it has a "open firewall" or "bypass firewall" option, enable it.
If it does not have a firewall option, disable the firewall on the MODEM, not the linksys. This is also called DMZPlus mode.
If the above does not work, go here on the entire instrucitons for setting up the linksys with your modem.
Aug 20, 2008 | Westell Wirespeed LiteLine 6100...
Siemens Speedstream 4100b Firewall?
4100 modem dont have interface and needs broadband connection in your network connection page
4100b modem have an interface and can access interface by the IPADDRESS of 192.168.1.64 and default gateway of 192.168.0.1
by accessing the default gateway using address bar of internet explorer browser it will be easy to configure..
FIREWALL: all AT&T modems firewall are safe and compatible to use to OS that has a built in firewall
Jun 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
FIREWALL ON P2P
There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
Sep 25, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Siemens Se5954 (120-5954-003) Firewall Logo
123 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
