Question about Refrigerators
Ice maker door does not close fully, letting in air and thus there is now ice on the inside of the freezer
  • Dougt411 Apr 30, 2008
    ice maker door has completely loosened, letting in warm air and causing ice to leak down to the drip pan and on to the floor. I need a way to reattach the door.
  • lvmining Jan 17, 2009
    ice maker "trap" door has come loose and needs to be reattached.
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 28, 2008
We have connected the water line - unit made one or two batches of ice. Unit now not making any ice. Interior of freezer is covered with frost. Checked manual - freezer air vent is not blocked, ice...
Is the frost all snowy. Sounds like an air leakage. Check the door gasket to be sure it is sealing. Check to make sure the door is fully closing. Put a level on the top and look for a 1/4 bubble tilt backwards to ensure the door is closing properly.
Jul 12, 2011 | Samsung RFG293HA
The fridge is all working ok the freezer is all working ok but the ice maker is not working i have removed the tube that goes to the water part at the back and blew down it an it is not blocked
Hi and welcome to FixYa, I am Kelly
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Ligt stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
Here is a link to the steps on how to troubleshoot an ice-maker.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Let me just add that many ice-maker related problems are due to the freezer temp rising above 16 deg F. The freezer starts warming up due to ice build up on the evaporator coils and then the internal air-flow is blocked by the ice build up causing the temps to rise. Look closely at the back of the unit for any signs of ice build up.
If you see ice build up......
1. Unplug the unit
2. Remove the freezer contents
3. Place a fan directing air into the freezer for just over 2 hours. (Water mess!)
4. Clean up the excess water and restart the unit. (Add freezer content)
5. After 8 - 10 hours check for ice production.
If after doing the above you have ice production then most likely you have an automatic defrosting problem.
If it still does not make ice, the steps in the link above will isolate what has failed in the ice-maker.
Before testing the ice-maker using the steps in the link.. I recommend you peform a manual defrost with a fan. If 8 - 10 hours after the manual defrrost you do not have ice production,, use the link and troubleshoot the ice maker.
Thanks for choosing FixYa,
Kelly
Jan 31, 2011 | Refrigerators
I have a side by side fridge freezer. The fridge compartment is freezing the food. can you help?
check thermostat for loose or damage connection but check the damper/blend door -located -in freezer where the fan is located and in the fridge where the air blows in is a duct and inside the duct is a damper -door that opens to let in cold air from freezer and closes when the fridge reaches temp some times ice or a piece of debris restricts it from fully closing or the unit gets stuck open--
Nov 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Area between the doors on the side by side are really hot.
Hi!!! the door was left open some forgot to close the door..if you have more problems let us know..Good luck..
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
GE refrigerators door
what is the model of the unit, sound like a door flapper selenoid issue
May 06, 2008 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice in freezer compartment
I have seen this problem with the LG freezer unders. There is a air leak that is getting into the freezr allowing the moisture to frost up at the back of the freezer. It will form frost all over too. Since your unit is 8 month old call Lg and let them deal with the problem. At my last Lg training the problem is with the air damper in the fresh food section may not be closing fully. So Call for service.
Jul 12, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
