Question about Eclipse AVN5495 Car DVD Player
Dvd disk won't eject???
I have a fujitsu ten ndkt-w52 model. a 2din touch screen dvd player. it came from japan. everytime i insert a dvd disc...the player will not read the disc and i also cant eject it. but when i insert an audio cd... the player reads it. what seems to be the problem???
  • habib1bg_4u Aug 21, 2008
This is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Posted on Jan 14, 2009
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
Disc won't eject
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it.
Joe Don
May 25, 2012 | Toshiba XDE500 Player
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
I inserted a disc and it couldn't be ejected, but I was able to insert another dvd and it plays. The touch screen became not very sensitive and responsive. What happened to my first disc? And how can I...
There is always a small pin hole in the tray of the DVD. Insert a pin through it and the tray will open mechanically. After removing the disk press the tray to close it.
Nov 08, 2009 | Pioneer AVH-P4000DVD Monitor
Why won.t the disc go to load. it keeps opening after inserting disk .when play is pushed it shows stop then ejects disk.Whats up with www.rca.com/customersupport
check the type of discs that are recognized with your dvd player. Some machines recognize dvdr- some dvdr+ some dvdrw+/- you may be using the wrong formated type of disc.Look at disc and see what type it is in the ring surrounding the hole especially if it is a copy
Sep 29, 2009 | RCA Televison & Video
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
Carrozzeria avic drv 250 problem
check out bootdisc.ru
I have the drv-250 and download the disk from here....works perfectly now
Jun 21, 2008 | Pioneer AVIC-N2 Car DVD Player
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Eclipse AVN5495 Car DVD Player Logo
789 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
