Question about Samsung HCN653W 65" Rear Projection Television
Convergence Is this an easy fix or should I call a repair person? Would you refer to a certain parts place?
    Scholar:
  • 131 Answers
You can use mcm electronics. if your good at soldering and removing board. www.mcm electronics.com
It is worth having a repair person do it 250 and 300
good luck doctor video
Posted on Apr 29, 2008
Convergence bad on my 60pp9363h what part do i need to order
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 01, 2011 | Philips 60PP9363 60" Rear Projection...
Bowed lines; 3D screen; convergence fixes for a few minutes
Jul 31, 2011 | RCA P52926 52" Rear Projection Television
Want to perform manual convergence. when i get to the convergence section, buttons on tv will not perform the task. remote has not worked since quite new according to previous owner. Is there a reason for...
Jul 28, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Convergence
Jul 17, 2011 | Mitsubishi WS-55857 55" Rear Projection...
Automatic convergence feuses
Jul 13, 2011 | RCA HD52W66 Projection Television
I believe this is indeed a convergence problem. it looks like its in 3D. this happened after i moved it from one place to another in the living room. how di i fix this??
Jul 12, 2011 | RCA HD56W66 56" HDTV
Blurred picture red and blue shadows
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are dis aligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to refer to the manual on how to go about it
Nov 29, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
I HAVE A DOUBLE VISION, BETWEEN THE GREEN AND RED, THE GREEN IS SOMEWHAT WARPED OR ARCHED.
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Jun 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Hitachi 43GX10B, picture is warped like being squeezed in the middle from top to bottom (concave). And can't line up the colors on the top and bottom rows in digital array
You will need to replace the two STK 392-110 convergence chips; most of the time in this model it is fairly easy--there are two versions of this set and one is more easy than the other.
If you are a do it yourself person I can step you through the entire repair--total parts cost will be under thirty dollars and I can also tell you everything you will need and the best place to get the parts.
Let me know if you know how to solder etc as this is involved in this repair.
SD TECH
Mar 19, 2010 | Hitachi 43GX01B 43" Rear Projection...
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Samsung HCN653W 65" Rear Projection Television Logo
78 people viewed this question
Henry  Thomas
Henry Thomas
