Question about SanDisk Sansa c200 MP3 Player
Not turning on
The light behind the buttons go on but the screen stays off and no music plays. I tried taking the battery out and that doesn't help and also It doesn't even start to charge when i connect it. what does this mean?
  • EddieChub May 13, 2008
    Updated the software on my c240, and light on power pad come o, but now screen. Also, will not do the reset (lock, rec, connect usb).
    Probably caused by installing and removing Rockbox first.
    Under rockbox, was not connecting to computer via USB, so I decided to remove and update the native runtime.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
Wont play music
Even though you charged it all night, the battery may not, in fact, have charged. You may need to replace the battery, especially if it is a few years old
Jul 20, 2013 | Mach Speed Eclipse Cl4Bk
Yahtzee wild touchscreen doesn't work
if you turn on the light button and it just plays music it is in demo mode. Wait for the music and light to go off and hold down the roll button for three seconds. That should do the trick just hit the light button again pick number of players. if that doesn't work you may have weak batteries try the reset button or your game may just be defective.
Mar 07, 2013 | Hasbro Yahtzee Wild Hand Held Game
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
My ipod classic 7th generation is frozen. the light is on but it doesn't respond to any buttons or the wheel. I tried to press the home button and the play button but it's not doing anything.
Hi! (: i'm not sure if this will work, but when my ipod did this, I left it in a cup of rice for a few hours, then I left it charging for a while until it turned on and showed the home screen. If this doesnt work, try calling apples technicians on their website! They can help sometimes..
[Also, yahoo answers might have a better solution] Good luck!
Dec 04, 2012 | Apple iPod classic 7th Generation
My sanyo vps-s1414 camera seems to shutdown when I take pictures - i take a picture and the lcd screen goes blank and the green light showing the camera is on goes off but the lens stays out. I have to...
1. Try cleaning the battery contacts inside the battery compartment.
2. Try removing the media card, then turn on camera. If its ok, then you have a bad media card, try formatting the media card.
Jul 31, 2011 | Cameras
My ti 84 plus does not want to turn on, i thought it was battery problem so, i bought new batteries but i stil have a blank screen.
Could it be that your screen has been dimmed in error. Turn the calculator on & press the 2nd key and then the up arrow. This darkens the screen.
If this doesn't work, try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 21, 2011 | Texas Instruments TI-84 Plus Calculator
Wont turn on
you need a new battery for you zen
look on
or do a search for creative labs zen vplus battery
on the inetrnet
May 25, 2009 | Creative Labs ZEN V Plus MP3 Player
My play button wont work
The only thing I can think of is try new batteries. I know when mine plays and then shuts off by itself, the battery needs to be changed.
Hope it helps
Apr 01, 2008 | Coby MP-C883 MP3 Player
Second sansae250 in less than two weeks with the same problem
pull the menu button 15s or more... if u dont get it to quit well... u got to take battery out
Jan 08, 2008 | SanDisk Sansa e250 MP3 Player
It died
The same thing happened to me and i had no idea what to do. I tried e-mailing the creative headquarters but they wouldnt give me any advice. Finally i realized that there is a reset button on the botom of the player that i never noticed before. If you hold in the play/pause button, hit the reset button, and then release then play/pause button it should take you to a screen where it gives you options on what to do with your player. What i did was reboot it and nothing happened. Whatever you do, DO NOT hit format, or else you will lose all of your picture and music files. I got really frustrated with this problem so glad i could help out.
Apr 15, 2007 | Creative Labs ZEN SLEEK MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
