Question about Philips E-Box FTR9965 DTV Receiver
Cp?? on PiP board
What is the cp (capacator? clock processor?)
  • nikosdenis Jun 20, 2008
    What is the broken cp and where is the PiP board
    Problem Solver:
What is the broken cp(capacitor)
and were is the PiP board
Posted on Jun 20, 2008
Phaser 7400 14: real time clock
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Dec 07, 2014 | Xerox Phaser 7400/DX Laser Printer
What is the processor type and speed, RAM size and Hard drive capacity of packard bell R1005 laptop
It has a Celeron M processor, with 1500MHz clock speed, 512MB of RAM and a HDD capacity of 40GB and a 15.4'' screen.
Jan 29, 2011 | Computers & Internet
My cp is nt working, the power supply is nt coming in the cp, it is a intel product and 3months old. i need service
have your power supply changed with the same product number (to maintain compatibility). A faulty power supply reduces that amount of power that the board may need and in that case the cp may not function cause it does not get the right amount of power it needs. Also try changing your power outlet source and cord to see if it will help.
good luck
Jul 04, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
What's the max capacity for ram on 600 mhz AMD athlon64
Download the manual for *********** board and it will tell you. If you are running windows 32bit I think the max usable is 4GB. If you are running a 64 bit OS then then it is more. The manual will give you max ram per slot and what slot to put them in.
Jul 09, 2009 | Quadrant Athlon , 600 MHz (CP-AMD-ATH-600)...
I have asus M.b p4 sys133 and it has a 2.00 MHZ processor .. when i gave changed it with another with 2.62 MHZ it didn't work and the computer was hanging .so what's the problem ???? the processors were...
Hi there.
The computer is probably struggling with the clock speed of the new processor.
Did you reset the BIOS setting?
If you didn't go into the BIOS and set it to default settings, hit F10, save the changes and restart the computer.
Clock speeds should now be reset and the computer should work. Also you should make sure the system memory is seated properly.
Good luck
Jun 10, 2009 | ASUS (S370L) Processor Board
Jumper setting
hello
can you send me this page to check with you if you want
AYADI
Mar 14, 2008 | Iwill VX133 (MAVX133) Motherboard
Snowy picture in all video sources -Sony Kp53xbr200
I'm working on the same problem. I posted a little about this problem under another question for the 53XBR200. From what I've learned so far with experimenting and studying the schematics is that the problem is with the BR board which is the module that handles upconverting. PIP video goes through the BM board/module. You can pull the BR board out of the set and still have the TV work as long as you keep it in PIP modes. Likewise, you can pull the BR board out, but the set will turn off if you try to go into any PIP mode. The problem with static on every input only remains in full-screen video. As you've noted, all inputs work fine as long as you remain in one of the PIP modes. It does look like the BR board is discontinued. I would like to know how to get a replacement/repair if anyone knows about this. My only hope to get this set functional again is to either force the video to bypass the BR board, or repair the BR board itself. If it's a discrete component on the BR board (capacitor, resistor, transistor) then it might be possible to salvage a repair. If it's one of the upconverting chips, then we might be SOL. I've tried to jump the video signals around the BR board, but this didn't work and the picture looked distorted. I think the problem with this idea is that the video processor might be expecting 480p/960i video and by bypassing the upconverter I'm sending 480i video into the video processor. I'm going pursue this idea some more as it might be the only way to salvage the set from the trash bin.
Dec 31, 2007 | Sony KP-53XBR200 53" Rear Projection...
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips E-Box FTR9965 DTV Receiver Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
