Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
Emonster 600 won't boot up
My emonster 600 was working fine, I turned on the PC and the light keep blinking fast and no signal to the monitor. The cooling fans are running but it appears nothing else is. I unplugged the machine waited and plugged it back into the outlet, it immediately started the same thing without touching the power button. I tested the PSU, I had 10.5 volts on the 12 volt side and 3.7 on the 5 volt side. Do I need a new power supply or should I try resetting the CMOS? Thanks for any help.
unit will not boot-up, fan runs (loud) but monitor reads 'no signal'. Have read about possiblily changning out the 'psu' or 'processor' sounds intimidating!! processor is AMD 64 Anthlon. If anyone can give layman instructions it would be appreciated...also is there a risk that all my data is wiped-out?? This started after I logged out I went to turn-off computer last night, and when I checked computer this morning--monitor read 'shutting down windows' it was like the computer was 'frozen'. so I had to turn it off manually, and ever since it will not boot up. any help is appreciated!
  • 62 Answers
You should not loose any information seeing that all information is held on your hard drive. As for changing out the processor, it seems pretty intimidating but is rather simple. When you have the side of the computer removed and can see into the tower you see the CPU (processer) fan. To the left side of the fan you see a little metal prog/bracket. Insert a flat head screwdriver into the slot and press down gently and then use leverage (just a little) to pull the bottom of the bracket out from it's holding. Once this is unhooked the fan will come off very easy. Next... at the bottom side of the square holding the processer will be a brown tooth pick like pice of plastic. Pull it gently down (twardse the bottom of the computer housing) from the left hand side then up to the right. Pretty much a fulcrum... the pulling down lets it come loose from its holding then pulling it up (directly to you from left to right) will unseat the processer. Once you have done this the processer will come out very easy with two fingers grasping on to two sides of it. When you get the new processer it should come with the "goop" (the silver stuff you see on the bottom of the fan and the top of the processer. Clean the bottom of the fan of the goop and apply fresh goop. Then apply a light coating to the processer. Place the processer back into it seating and repeat all steps backwards. If you need more help feel free to ask... I have an old E machine in my stack or old puters that I can do a play by play with and take photos of the steps and post the links on here for you if need be. As for your power supply, if it has that much of a loss I would sudgest replacing it.
Posted on Apr 29, 2008
Video driver for e machine e monster 600 with wins 98 missing.
you can go to google and search it then download or go to install hardware and get it there
Jul 08, 2011 | E-Machines eMonster 600 PC Desktop
Can I install Windows XP Professional on an Emonster 600 ?
Yes you can...
Installing Windows XP on a Emonster 600 is the same process as installing Windows XP on any Windows-compatible personal computer. The process is not difficult, and can be completed quickly.
#1 Insert the Windows disc and restart your computer. When prompted to press any key to boot from the CD, press a key. Windows will begin the set-up process.
#2 When a list of hard drive partitions appears, delete each of them by pressing "D" to delete and "L" to confirm deletion. When finished, you should only have one choice: "unpartitioned space."
#3 Press "Enter", then format using the NTFS file system. Do nothing while Windows begins to install.
#4 Wait for Windows to restart. When the process continues, enter the product key, the time and time zone, and your name when prompted to do so. Allow the installation to continue; it may take some time.
#5 when Windows restarts again, continue the process using the on-screen instructions. The process will vary depending on your hardware configuration.
#6 Connect to the Internet and activate Windows once you reach your desktop. If you can't, you can also activate Windows over the phone. Installation is complete.
Oct 03, 2010 | E-Machines eMonster 600 PC Desktop
How do I formatt the hard drive on my emonster 500a PC?
Same as any other system. Insert your Windows CD, go to the recovery console, format. You know you will have to reinstall everything after that.
Aug 04, 2010 | E-Machines eMonster 500a PC Desktop
Monitor screen while booting says out of range then turns blue.
while booting into the Operating system try pressing F8. It will take you to the os menu and select VGA loging in mode in that. Later after entering the operating system reduce your monitor resolution say 800 * 600 it should fix the problem.
Nov 27, 2009 | E-Machines eMonster 550 PC Desktop
This machine has WinXP pro on it. When shutting the machine down, it goes into "It is now safe to turn your machine off." when you hit the power button, it apparently goes into standby?, because the power...
Check the BIOS to see if ACPI is enabled.
Might try looking in event viewer/Application or System log files to see what may be hanging it up.
It may also even be a virus.
Oct 03, 2009 | E-Machines eMonster 500a PC Desktop
What sound card to purchase
this unti has 3 expansion slot (pci) , i would go with a sound blaster audigy2 or better if you are not going to use the onboard sound..
Apr 04, 2009 | E-Machines eMonster 600 PC Desktop
EMachines eMonster 500A Restore Disk
I suggest finding the specific drivers that he deleted. Typically, when a computer begins to get slow, either 1 of 3 problems occur. 1. The drivers are insufficiently up to date. 2. There's too much clutter on the hard disk, RAM, and CPU. Lastly, driver files and start up files get deleted. The best way to fix that slow problem is downloading the driver files.
Feb 05, 2009 | E-Machines eMonster 500a PC Desktop
"E Machines" welcome screen
Press F2 or Del during boot up and you will access the bios. You will have to look through the menus for something like 'logo on boot up' enable/dissable.
Jan 13, 2007 | E-Machines eMonster 600 PC Desktop
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
Top AMD Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
