Question about Dryers
Dryer problem I have whirlpool dryer, the vent blowing the hot air into the dryer is really hot, just about to the point of scalding! It also has a few squeaks and noises. It is only 1.5 yrs old, any ideas?
  • 1,073 Answers
Operating thermastat or restricted vent to the outside
Posted on Apr 28, 2008
If the drum is turning and air is blowing then the most likely causes are thermal fuse trip, thermostat fault or heater fault.
Some good points mentioned on this site.
Discussion about thermal fuse on this site.
May 05, 2014 | Dryers
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
there could be a blockage which is preventing the hot air from escaping
Aug 07, 2012 | Whirlpool Dryers
Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Whirlpool WED5300VW0 dryer--gets hot, tumbles,
This definitely appears to be an air flow problem. Take off the vent and see if it is blowing any air. If air, lots of it, comes out the dryer, the vent is clogged and needs cleared out. If no, or very little air blows out the dryer, the blower wheel could be broken, or there is a serious clog. Check the lint filter and look inside where it goes for anything that might be restricting the air.
Jan 03, 2010 | Whirlpool Dryers
How long should it take to reach a hot temperature?
Try disconnecting the vent at the back of the dryer and run the dryer with the air blowing just into your laundry room for a few minutes. Air flow should be strong and you should feel discharge air heating. It still sounds to me as if the dryer has flex vent and maybe does not line up with the dryer outlet, so that when the dryer is pushed back into place the actual space left for the exhaust air to pass through is very small. If this is the case, there is a telescopic low profile aluminum vent available to solve the problem.
Aug 28, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
70 people viewed this question
Top Dryers Experts
