FixYa.com
Tags:
Bissell 1699 ProHeat Clear View Upright Steam Vacuum
NOT DISPENSING
posted by jazzyj395 on Apr 28, 2008
THE RED THING ON TOP IS NOT GOING ROUND AND ROUND. NOT DISPENSING WATER AND SOLUTION.
it wont throw water
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 01, 2008
FixYa! (100)
michelle313
Rank:Apprentice Apprentice
Rating: 95%, 3 votes
This is a common problem with these cleaners. The solution seems to cyrstalize and black the small tube near the heater. Take apart the handle and the run a small screwdriver or pipe cleaner through to unblock the small tubes, put it back together and it will be like new. I had the same problem with my clearview. I would not run vinegar through the machine, it can eat up the seals.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 29, 2008
Helpful (85)
reddevil6
Rank:Guru Guru
Rating: 87%, 979 votes
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines.
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
