i was not paid or you charged. Sorry I couldn't help as I was under the misconception that you were trying to replace the broken part. Sorry Timi was not paid or you charged. Sorry I couldn't help as I was under the misconception that you were trying to replace the broken part. Sorry Tim
You can't post conmments that contain an email address.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
You gave me no help.How do I cancel the $20.00 charge?
