If it is an older type PS3 (Phat) on the left hand side of the console there is a small plastic cover. Using a small flat blade screwdriver, carefully prise one end of the cover outwards. There is a small cut-out on one end where the screwdriver goes. When you have this cover removed you will see a blue cross head screw. Remove this screw. You will also see a small wire clip that is attached to the side of the hard drive caddy. Pull this clip outwards. Carefully take hold of the clip and slide the hard drive towards the front of the console. The hard drive will then come out of the side of the console.
If you have a PS3 Slim the procedure is slightly different. On the bottom of the console there is a small flip out cover. Carefully remove this cover and there will be a blue cross head screw. Remove the screw. Now look below the slot where you put your discs. There is another plastic cover. Slide this to the right and remove it. Behind that cover is your hard drive. Flip the metal clip down and pull the hard drive out.
Hope this helps!
