Singer Featherweight 132Q Mechanical Sewing Machine Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't find my manual for my featherweight 132 and cannot figure out how to change feet; I broke a needle and the foot fell off and I can't get it back on; I haven't used this machine very much so I'm pretty clueless without a manual. sue
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Oct 21, 2010
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
681307
Points
4145
I realise this request is a few months old, however I just obtained this manual for another customer and I thought you might still need it. Sorry you didn't get an answer before but these manuals are very difficult to obtain . . . unless you want to pay $15 and order from the manufacturer.
http://static.quiltingboard.com/upload/2009/6/29/ef0b1a855e2c34e2d789f4d55debf9d7_6813.pdf
Click the link and the file will open. You can then view, save and/or print the manual. If you can't open the file, you also need to download and install Adobe Reader:
http://get.adobe.com/reader
Better late than never, I suppose!
Please rate this solution if you find it helpful. Thanks.
When I have the walking foot on the needle hits on the back of the foot.Janome 4800 memory craft
Is it a Janome brand walking foot? some generic feet and other brands don't fit the older Janomes.
4helpful
There are different kinds of single needle foot, What are these?
If you take a look at this website you'll see the different feet for some makes
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
I assume you mean what are the different feet used for?
General purpose foot will have room for the needle to swing through wide stitches, but enough foot to hold the fabric and move it through against the feed dogs. This is the one you use most.
A straight stitch foot will have a little hole so that the needle only goes through a small area and the fabric can't move to give a neat plain straight stitch.
Plastic wide toe foot is good when you need to see what you are sewing onto such as applique (sewing a piece of fabric onto another with a wide satin stitch).
Teflon coated foot is good for slippery fabrics, it grips well.
A roller foot is great for textiles like leather and vinyl which don't feed nicely.
Then there are lots of feet for turning the fabric to sew it such as a rolled hem (these come in different widths so you can turn 2mm, 4mm or 6mm for example).
Felled foot (like the side seam on your jeans) joining two fabrics in a felled seam
Then there are feet for quilting and darning where you need to move the fabric smoothly in different directions, these will be small foot area and open stitching space usually.
Walking foot is a special one, part of the foot moves because a part of it clips around the needle bar and the up and down movement then activates the foot so its little teeth help to move the fabric from the top to supplement the normal feed dogs below. Pfaff machines actually built this function into their machines some years ago to give even feed from top and bottom. Great for quilting thick fabric sandwich or sewing together fabrics that want to slip or not feed smoothly.
There is also similar info here http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ which may help you to see the different uses and feet available.
Most manufacturers will sell their machine with 4 or 5 of the most used feet but often have more to buy aftermarket. And many feet between companies look very alike so if you have a clip on foot from one brand it may work on another machine with a clip on foot.
I hope that this is what you were asking.
Would you please advise how I put a zipper foot on my brother bm-3600, the needle will not align with the foot when I put the foot down! Thank you.
Did a google image search, this looks like a newish machine so I'd assume clip on feet?
Put the foot on the pressure plate, lower the foot on and align so it clicks into place.
Couldn't get an image of the foot but many zipper feet are designed to mount either left or right side of the foot so you can sew both edges of the zip in the same direction, ie pressure foot to left of the needle for one side, and to the right of the needle for the other side of the zip, you want to stitch in the same direction to avoid creeping.
Some machines you change the change the needle position to the left or right in order to get up close to the zipper foot.
Probably a manual would assist explaining this better, if you don't have one for the machine, I'd suggest that you obtain one.
I have q 410Q and I broke a needle while sewing.
THANK YOU I LOOK I FORWARD YOUR ASSISTANCE ,EVEN SOME LITTLE ASSISTANCE FOR NOW ON E-MAIL BECAUSE IN TROUBLE
1helpful
3answers
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
