Question about HP Photosmart C6180 All-In-One InkJet Printer
Print failure error # oxyc19ac3ff
Printer will not print.
  • 26 Answers
Oooh too bad.. did you get that error # oxyc19ac3ff? on what printer model? that would be ink sys failure. might as well buy new printer or if your still in warranty then ring hp and have it replace
Posted on Jun 11, 2008
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
Ink System Failure Error: Oxc18a0001
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 13, 2010 | HP Photosmart C7180 All-In-One InkJet...
"ink system failure Error: 0xc19a0003"
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 19, 2009 | HP Photosmart 3210 Printer
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Zebra TLp 2844 (printer not connected error message )
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Jun 23, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Hp CM8060 error code 49 4C02
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Apr 22, 2008 | HP Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
