Question about Kenwood KDC-138 FM / AM Receiver
Clock Display I just had this model installed 1 week ago. I could see the time on the screen. I set the time in the menu mode and when I exited the menu mode, the time was no longer there. I need to know how to get it back.
Go to stand-by and then to set radio
Posted on Sep 06, 2008
How do I set day and date? All else is set
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Dec 09, 2014 | Westclox 70026A LCD Atomic Digital Alarm...
How do I set the clock on a kdc-mp522 CD player
Step 1:
Enter Menu mode
Press the [MENU] button for at least 1 second.
"MENU" is displayed.
Step 2:
Select Clock Adjustment mode
Press the [FM] or [AM] button.
Select the "Clock Adjust"/ "CLK ADJ" display.
Step 3:
Enter Clock Adjust mode
Press the [Down Search] or [Up Search] button for at least 1 second.
The clock display blinks.
Step 4:
Adjust the hours
Adjust the minutes
Press the [Down Search] or [Up Search] button.
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Hope that helps.
Cheers,
Scott
Jan 15, 2013 | Kenwood Sirius KDC-MP522 CD Player
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
How do you set the clock on the Kenwood DPX302
In the standby mode:
1. Push the Control knob towards up or down, select "CLK ADJ"
2. Press the Control knob for about 1 second, the clock display blinks
3. Push the Control knob towards up or down to set the hour
Push the Control knob towards right or left to adjust the minutes,
4. Press the Menu button
Mar 01, 2011 | Kenwood DPX302 CD Player
Uhm How do you set the time ?? i have the clock up but i dont know how to set the time to what time it is !!!
1 Select Clock Adjustment Mode
Push The Control Knob Towards {FM} or {AM}.
select the "CLCK" display.
2 Enter Clock Adjustment Mode
Press the Control Knob For at least a second
The CLCK display blinks.
3Adjust the hours
Push The control knob Towards {FM} or {AM}.
Adjust the Minutes
Push the control knob towards {<<} or {>>}
4 Exit Clock Adjustment Mode
Press the {Menu} button.
Dec 26, 2010 | Kenwood KDC-135 CD Player
Setting the clock
Enter Menu mode
1 Select Clock Adjustment mode
Select the "CLK ADJ" display.
2 Enter Clock Adjust mode
Press the [4] or [¢] button for at least 1 second.
3 Adjust the hours
Adjust the minutes
Press the [4] or [¢] button.
4 Exit Clock adjustment mode
Jan 09, 2009 | Kenwood KDC-MPV7019 CD Player
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Want a clock setting on my display window
According to the manual, in STANDBY MODE, push the control knob towards FM or AM and select CLK ADJ. Press the control knob for at least 1 second, the clock display blinks. Adjust the hours by pushing the control knob towards FM or AM, and the minutes by pushing the control knob right or left. Exit CLK ADJ mode by pressing the MENU button. Hope this helped.
Feb 07, 2008 | Kenwood KDC-MP235 CD Player
Kenwood KDC-138 FM / AM Receiver Logo
236 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
