Question about Sewing Machines
Machine stitching Stitches bunching up on back of material with long loops
  • 2 more comments
  • bucko36 Jun 15, 2008
    not stiching right
    not stiching right
  • Anonymous Jul 21, 2008
    stitches bunch up under fabric.  usually rethreading machine solves this problem, but not this time.  I've adjusted the tension, the stitch length, the needle size....nothing is working.  I'm sewing on a fine, densely woven fabric that is shiny and slippery.  I just finished sewing on muslin and linen with no problems.
  • davidstitch Nov 24, 2008
    cotton looping under material whie stitching
    Problem Solver:
I had the same thing happen with my machine, turns out I had the bobbin in backwards. Check your bobbin make sure its not backwards.
Posted on Apr 28, 2008
How can I stop my material sliding around when I am sewing?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
I have a problem with sewing, the stitches on the top are tight and the bottom stitches look fine, when I sew the material is bunched up.
The bobbin thread is too tight it's either getting caught on something or tension of bobbin needs adjusted
Mar 05, 2015 | Sewing Machines
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Just has annual service which included fixing stitches looping/bunching on bottom. Now stitches are wavy on the bottom.
Sounds like your service man hasn't properly set up the rotary hook retainer - take it back !!!
Jul 16, 2011 | Bernina Artista 180
The thread on the top side of my material starts looping after 4-5 stitches. I've tried every number of thread tension, and even on 0 it loops on the right side of the material, not on the back.
Check the tension on your bobbin thread. When you hold it by the thread and let it dangle does it just drop down without any resistance at all? If so then you need to tighten it a bit. If the bobbin thread is too loose it can not pull the top thread down enough thus puts the loops on the top side of the stitch.
Feb 25, 2011 | Brother LS2125i Sewing Machine
Mylock 634D looping left needle stitches
Make sure the thread is in the tension disks. Do this by pulling the thread backwards towards the spools. Also set the tension on zero and check for any fluff, or thread that is stuck in the disks, preventing them from closing properly. Good luck
Jan 09, 2009 | Janome MyLock 634D Mechanical Sewing...
Looped stitches on back
thanks but can't find a screw on the bobbin case, could you be more specific?
Dec 26, 2006 | Kenmore 19606 Computerized Sewing Machine
Sewing Machines Logo
197 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
