Back to:
Tags:
VCRs
Generic problem for all VCRs
Tape is locked in Sharp VCR (by 2 users)
posted by Jo conrad on Apr 28, 2008
I have a sharp xa-905 that the tape is in the vcr and the indicator on the front says it is locked. I can not get the tape out
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bhollyt, posted on Jul 17, 2008
I have a Sharp VC-685U - made in 1986. A tape is stuck inside. If you plug in the machine it makes noise. If you try to press any of the buttons, it does nothing - no sound or movement of any kind. It doesn't try to eject when you press the botton. I have taken off the top cover and looked to remove the tape deck, but there is a black plastic piece in the way on the right hand side. Not sure what to do at this point. I tried moving the gears on either side of the deck, but they won't move. The machine is not that important to me, it is the tape I want. I hope you can help me. Thank you for your time.
Solution #1
posted on Apr 29, 2008
Not Rated (0)
eastexas
Rank:Wiz Wiz
Rating: 84%, 20 votes
take the case off and see if the tape is stuck around anything. if not, remove the tape deck very carefully (make sure it is unplugged first). you should be able to remove the tape fairly easy. the tape may be wrapped around something inside of the deck there, or the loading gears could be out of synch. and if it happens again you might consider getting a new vcr because to replace a new loading deck is cost prohibitive because vcr's are so cheap now.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tape is locked in Sharp VCR:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
recorded a programme of t.v, on playback got the right...
VCRs
What is mdel code for VCR EWV404?
VCRs
I can't figure out how to tape a tv show on the vcr mode,...
VCRs
Trying to engage VCR to TV [Audio logic P1430] without...
VCRs
I have a hitachi video recorder vt-rm800ev and i need a...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
