Cannon NP6560 I get error e005. I would like to try resetting but need to know how to get into service mode. I have the repair manual but don't know where the "service mode switch" is.
  • 1,326 Answers
A E005 is the cleaning web counter. If you have replaced the cleaning you can reset the web counter in service mode under counters... The service switch is right next to the total meter in the front of the inside cover of the copier.... Once you press it you will see a little "$" sign shows and hit the "*" "6""*" and courser down the the web counter. You have to hold down the Clear botton and the hit the service switch to reset the counter back to zero... Good Luck
Posted on May 11, 2008
Hello, we are having an error pop up and I was wondering if it can be fixed here or if we will need to call in an expert and do some repairs/replacements on the device. We have a Cannon Imagerunner 5000...
this is error related to the fixing web cleaning belt. Sthis error appears after certain number of copies and means that you need to replace it.
For first aid you can clear the error in service mode. To do this on copier panel:
1) Press the user mode key ( ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( )
Choose:
COPIER>COUNTER>MISC>FIX-WEB
and
COPIER>COUNTER>DRBL-1>FX-WEB
Turn the copier off and back on.
Now you can copy/print, but call service support for fixing web replacement.
Hope that helps!
P.S.
In rare cases, E005 can occure because broken web clutch or if you do not copy in big ammount, so the web gets stuck on fixing roller and the E005 rises because the web clutch cant operate.
Aug 19, 2011 | Canon imageRUNNER 5000 Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
E005 - which part(s) to replace?
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
Nov 17, 2009 | Canon ImageRUNNER 330s Copier
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
I am getting error code e005 0100 how do i reset
E005 Error code details
  Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
 0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
Sep 04, 2009 | Canon CLC 1180 Copier
ERROR E005-0000 CANON C2058
Thae error means the fuser web has run out
you will need to replace the web and the reset the code in service mode.
You must replace the web before resetting the code if you dont
it will damage your machine.
if you want to know how to reset your machine please get back to me
Thank You
Feb 22, 2008 | Office Equipment & Supplies
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
351 people viewed this question
k24674
