Question about Samsung HCN653W 65" Rear Projection Television
The red convergence cannot be corrected
The blue is fine, but I cannot move the red. Can you just buy the Convergence Driver IC for red?
  • 131 Answers
There are two ic that should be replaced in convergence. It is like doing your breaks on your car you should do both sides. the parts are only 30. dollars.there are differant kinds for each model
stk 392-150 or stk392-040 so on the part you need will be on the convergence .make sure you check the resistor around convergence ics if they are burned you have to replace them to.
a tv shop charges around 300.00 to fix this repair
good luck
thanks Doctor video leadingedegeelectronics
Posted on Apr 28, 2008
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Which IC controls the blue convergence
Usually the second IC controls blue example if the two ICs are IC6001 and the other is IC602. 602 would usually control blue the first IC will almost always control red.
Apr 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Blue Convergence Problems
You will need to replace the conversion IC that controls the blue STK392-110 or STK392-120 however these are so cheap I recommend replacing both as the red wont last much longer. As they usually wear out around the same time. Heres a link where you can buy the replacement ICs and they include step by step instructions on how to install the new ICs.
Mar 29, 2008 | Philips 43P8341 43" Rear Projection...
Auto focus convergence on blue doesnt' work
this is an idication that eather the convergence ic's or convergenc ic output resistor have blown
Feb 16, 2008 | Samsung HCM422W 42" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
convergence ic bad
Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
