Question about Nokia E50
Nokia E50 Problem
Phone freezes up. Then not easy to switch on. When the phone is called it does not ring for about 10 seconds as if its on silent
    President:
  • 169 Answers
You can hard reset the phone (factory settings)
"power off - hold 3, green call and * - power on while holding"
Please note this will format all the saved information stored in phone memory.
Posted on Jun 19, 2008
Hey this is formating nokia e50 :S
Posted on Sep 12, 2008
Nokia 6700 when put on silent does not work, i.e.when on silent i can hear both tones for call and text
Why I can not get my nokia 6700 to go silent? still hear both ring and message tones?
Feb 24, 2010 | Nokia 6700 Classic Cell Phone
How to get out of Silent Mode
IF UR PHONE IS NOKIA THEN PRESS # KEY FOR 3 SECONDS THEN UR PHONE IS OUT FROM SILENT MODE.
IF SONY ERICSSON THEN VISIT IN GENERAL PROFILE & CHANGE UR RING SETTINGS.
Feb 01, 2010 | Cell Phones
I switched my phone on silent one night and ever since it wont ring and no sound
it should go back to ringing by depressing the volume up button on the side of the phone, if this fails I would call your carriers cust suppport. hope this helps.
Oct 27, 2009 | Nokia N95 Cellular Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
HOW DO YOU MUTE A NOKIA 8800
To mute the ringing tone, select Silence. Then either answer or reject the call.
you can also mute sound during call.
Mar 05, 2009 | Nokia 8800 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Turn off rings durring recieving the call
You can go in options-phone settings-phone profiles and press silent.....
I had the same phone and the comand silent works:)
Sep 03, 2008 | Samsung SGH-D900 Cellular Phone
Nokia 1600
if you hold the hash key down for a few seconds, it should come off silent, but if it doesnt check your phone settings to find if your got you ringtone set to ringing or if its off, either way, it should all be in your settings.
Jul 25, 2008 | Nokia 1600 Cellular Phone
Nokia 7373 not ringing
hi there you need to go on to your tone settings and see if you got the incoming alert '0ff' because this is one of the main reason why your phone wouldnt ring, also check your on alret for calls and see if you calls switched off. you may also need to go on to your profile and check if you have got it on silent and this is another reason why your phone may not be ringing. hope this helps
Aug 29, 2007 | Nokia 7373 Cellular Phone
Nokia E50 Logo
1,123 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
