POlaroid portable dvd player BT-6002
HI, my polaroid doesn't read dvd, instead it always displayed "bad disc". need help.
The laser that reads the dvd needs re-calibrating.
Posted on Feb 16, 2009
Need an answer about my Polaroid portable DVD player
either a dirty or bad optical pickup which reads the disc--if bad may not be economical to fix.
Apr 19, 2012 | Televison & Video
My polaroid portable dvd player is not working properly. so i brought it to an electrician to see what is the problem. he said that the problem is the motor. a 3.0v motor model CCM30-030R1-49. And the...
hi,
may be he is write. its a regular complaint with dvd players. in dvd players spindle motor (on which the cd rotates) will get damaged, its winding will get shorted. this will cause not reading of discs. replace the same. u can use any type of spindle motor using in portable dvd players.
ok
Jan 27, 2011 | Televison & Video
Polaroid Portable DVD player PDX-0758 reads bad disc for all dvds
the only way is cleaning the optic reader.Just wet in alcohol a swab -almost dry- and clean it.If this does not fix the problem,you may have to replace it.
Feb 15, 2010 | Polaroid Portable DVD Player PDM-0822BD
Polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Nov 29, 2009 | Televison & Video
BAD DISC PROBLEM ON PDM1058 POLAROID
you can try to clean the laser under the disc door
Aug 01, 2009 | Polaroid PDM-1058 Portable DVD Player
DVD Player that repeatedly says NO DISC for Polaroid PDM-0752
either needs to be clean or the REGION needs to be set up to 1 or ALL , LETS TRY WITH cleaning the OPTICAL LENS with a dry Q tip , gently rub a few strokes at the lens , and give it a try, if NOT then try to set the REGION to 1 or all, if still not reading the disc , then have to replace the optical lens, good luck , AJ
May 28, 2009 | Polaroid PDM-0742 Portable DVD Player
POLAROID PORTABLE DVD PLAYER CHARGES ON WALL ADAPTOR BUT NOT ON CAR CHARGER
You can buy it at followig link:
http://recoupit.com/Portable-DVD-Players/c177182/
http://cgi.ebay.com/Polaroid-MPA-6930A-AC-Power-Adapter-9-5V-3-33A_W0QQitemZ140312970734QQcmdZViewItemQQptZDVD_Players_Recorders?hash=item20ab4e05ee&_trksid=p4634.c0.m14&_trkparms=|301%3A0|293%3A1|294%3A30
May 08, 2009 | Polaroid PDM-1058 Portable DVD Player
Bad disc comes up on portable dvd player
Hi
you have bad Pick up lens and or bad Flex ribbon Wire.
Thanks!
Nov 12, 2008 | Polaroid PDM-0742 Portable DVD Player
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Polaroid DVD Player won't charge.
I had the same problem, which I attributed to having the plug in a power strip. Once I plugged it directly into the wall socket, I haven't had a problem since.
Oct 18, 2007 | Polaroid PDM-1058 Portable DVD Player
Televison & Video Logo
387 people viewed this question
Top Televison & Video Experts
